Please Help My projector just blew up !
Discussion in 'Projectors, Screens & Video Processors' started by jbalat, Feb 10, 2003.
  1. jbalat
    jbalat
    I have the TH-AE200 from PriceJapan
    It has only 60 hrs of use
    The PJ standby led was on. I pressed the on button and turned around to grab the keyboard.
    Then I hear a short circuit kind of sound and there was no power going to the unit.
    Close up there was a slight smell also.
    Someone please tell me that there is a fuse in this thing ???
    Its going to cost big $$$ to send it back.
    Any ideas ?
  2. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    Sounds like the PSU has blown, its quite common failure with small projectors.
  3. jbalat
    jbalat
    Is it something that can be fixed easily or do I need to send it back ?
  4. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    When mine went on my Plus projector I had to send it back.
  5. Kramer
    Kramer
    [moved from HTPCs ]
  6. jbalat
    jbalat
    All up it was going to cost $490 AUS to send it back to pricejapan and get a replacement.
    Definitely a lesson learnt for me.
    I will let you know how I go... (fingers crossed)
