Please help my confusion setting an an SR4300
Discussion in 'AV Receivers & Amplifiers' started by KraGorn, Sep 14, 2003.
  1. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I've just got an SR4300 and am reading the manual before installing it ... a quaint habit but one I find useful. ;)
    I'm confused about one aspect of the setup ..
    In SPEAKER SETUP one sets the volumes of each speaker, I understand this :)
    In SURROUND SETUP one sets the volumes of each speaker, I understand this :)
    I DON'T understand why one has to do this TWICE. :confused:
    Can someone please explain what it is one doing in the first step compared to what one is doing in the second? I also see there's yet another level-setting in the 6.1 CH. IN. setup.
    I'm migrating from a Nakamichi AV-10 and that only had one speaker volume setup phase.
    Cheers.
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    .Looking at my SR5300 the surround menus is in fact the same as the settings you have in speakers set up, but you have the addition of LFE level at HT EQ, I leave this set to off. You do not have to set them twice once they are set in one mode you will see the same values in the other, cant say I had thought about it before but there are in fact three ways to set speaker levels, SET UP/T.TONE button will take you directly there. Does this make sense?
    The 6.1 setting is however different the input for the 6.1 bypasses the internal DAC's and therefore has to be set differently
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Ah, I see, makes sense really just the manual simply describes the three volume setups as they appear in the various phases of the setup procedure and doesn't suggest what you say happens in reality.
    Thanks for pointing out the small differences between them, I may not have noticed those to begin with. :)
  4. tulloch2003
    tulloch2003
    Mar 21, 2003
    855
    Port Talbot
    +15
    @KRaGorn
    Hi how much better is the 4300 over the Nakamichi AV-10 for sound with films and music please.
    Regards Trevor
