Question PLEASE HELP ME!!!!
Discussion in 'AV Receivers & Amplifiers' started by BADDY32, Jan 24, 2018.
Tags:
  1. BADDY32
    BADDY32
    Feb 23, 2014
  2. dante01
    dante01
    Mar 5, 2009
    46,349
    +11,134
    DAB radio tuner.
  3. BADDY32
    BADDY32
    Feb 23, 2014
    but surely thats a good feature, but its £140 less with it? does that make any sense?
  4. dante01
    dante01
    Mar 5, 2009
    46,349
    +11,134
    Different retailers. One is obviously charging more for the model without the DAB tuner. The prices quaited aren't the suggested retail price.
  5. BADDY32
    BADDY32
    Feb 23, 2014
    Which would you go for then? The £199 or the £337?
    Is this a stupid question
  6. dante01
    dante01
    Mar 5, 2009
    46,349
    +11,134
    THe same receiver sans the DAB tuner from Richer Sounds who are selling the receiver with the DAB tuner via Amazon:
    Pioneer AV Receiver
    It is cheaper without the tuner.
  7. dante01
    dante01
    Mar 5, 2009
    46,349
    +11,134
    Not that I use my receiver's tuner, but I'd be more inclined to go with the DAB equipped model.
  8. BADDY32
    BADDY32
    Feb 23, 2014
    I don’t either. So the £199 model you reckon?
    The helps much appreciated :)
  9. dante01
    dante01
    Mar 5, 2009
    46,349
    +11,134
  10. BADDY32
    BADDY32
    Feb 23, 2014
    Looks like I’m getting the vsx531d. Supports 4K passthrough and hdcp 2.2. Exactly what I’m looking for.
    Separate question- I need to run a 10m hdmi lead from my amp to projector. I bought the attached image, will I have any issue watch sky q 4k?
  11. dante01
    dante01
    Mar 5, 2009
    46,349
    +11,134
    It is generally suggested not to use HDMI cables longer than 8m. The longer the cable then the greater the chances are of you experiencing signal dropouts. THis is more the case with higher bandwidth UHD signals. You may get away with it at 10m, but there's no way to gurantee any cable will work with all combinations of hardware.
  12. BADDY32
    BADDY32
    Feb 23, 2014
    Looks like I’ll suck it and see I think.
    What about 5m hdmi booster 5m hdmi? Do you think that’d work?
    One like the attached pic
  13. dante01
    dante01
    Mar 5, 2009
    46,349
    +11,134
    It is suggested that you use HDMI over fibre optic for long cable runs when convey UHD signals. This is however expensive. A 10m HDMI over fibre cable would cost you close to £200.
    Ruipro Hybrid Fibre HDMI Cable
    Using a repeater such as the one you've linked to is another option though, but one that may not be as effective or neat as using fibre?
  14. BADDY32
    BADDY32
    Feb 23, 2014
    Think I’ll chance it with my £11.99 special then. £200 wow :facepalm:
  15. Deeez Nuuutz
    Deeez Nuuutz
    Oct 10, 2005
    5,131
    Berkshire
    +1,128
    Do you definately neeed 10m ? Can get away with 8m by re-routing the cable maybe? If so, then there are other cheaper cables you can use for 4K that have been reported to work at full bandwidth.
  16. BADDY32
    BADDY32
    Feb 23, 2014
    I’d have to remeasure the room again to see. Can you recommend any 8m hdmi’s deez nuts? Lost when it comes to looking for them.
  17. Deeez Nuuutz
    Deeez Nuuutz
    Oct 10, 2005
    5,131
    Berkshire
    +1,128
    8m HDMI :
    JuicEBitz® 8m Premium 4K UHD White HDMI 2.0 Cable [HDCP 2.2 Compliant - HDR Graphics - 18Gbps + [email protected]] 24k Gold Plated Lead | Ultra HD | Ethernet | ARC | CEC (8m) https://www.amazon.co.uk/dp/B06Y36487C/ref=cm_sw_r_cp_api_iCEAAbCZWFRF4
    I’ve read that this cable works @ 10m :
    4K HDMI 2.0b Cable by Ultra HDTV 10m I Premium High Speed Lead I [email protected] (no stuttering!) I Nylon Braided, Metal Adapters, Ethernet, 3D, HDR, ARC https://www.amazon.co.uk/dp/B01FXRN074/ref=cm_sw_r_cp_api_uAEAAbHA2C43E
    I have read from various sources that this works perfectly but it’s 7.5m :
    AmazonBasics High-Speed HDMI 2.0 Cable - 7.5m / 25 Feet (Latest Standard) Supports Ethernet, 3D, Audio Return https://www.amazon.co.uk/dp/B014I8TC4E/ref=cm_sw_r_cp_api_QCEAAbAVGCJDJ
    Hope this helps :)
  18. BADDY32
    BADDY32
    Feb 23, 2014
    I kid you not, I took the plunge and got the first one you’ve posted haha.
    That’s without measuring though, so hopefully the 8m will do.
    Thanks for your help, I’ll keep you posted
  19. Deeez Nuuutz
    Deeez Nuuutz
    Oct 10, 2005
    5,131
    Berkshire
    +1,128
    Let me know how you get on.
    Worst case scenario it doesn’t stretch and you send it back.
    The 10m one I posted has also worked for a few users so you have a few options there.
  20. BADDY32
    BADDY32
    Feb 23, 2014
    I’ve done a rough measurement.
    Need to go up 2m (receiver to ceiling)
    Across my attic 4.5m
    Down to pj 1m (ceiling to projector)
    Across my attic in a diagonal, so fingers crossed.
    The 8m hdmi is coming Saturday.
  21. Deeez Nuuutz
    Deeez Nuuutz
    Oct 10, 2005
    5,131
    Berkshire
    +1,128
    You should be okay then.
    Just a word of caution, and I’m not patronising you or anything, but make sure you’re not putting any additional pressure on the hdmi connections when you fit the cable. Make sure you have a little free play each end so that the hdmi cable can go straight into the port with no stress on the connection.
    Better to find a longer cable than just making the one you have fit badly :smashin:
  22. BADDY32
    BADDY32
    Feb 23, 2014
    You're making me nervous now haha.
    any advice is welcomed :)
  23. BADDY32
    BADDY32
    Feb 23, 2014
    Got the 4K amp and receiver and the 8m hdmi fit ok.
    Just waiting on sky q coming on Thursday then I should be good to go :)
  24. Deeez Nuuutz
    Deeez Nuuutz
    Oct 10, 2005
    5,131
    Berkshire
    +1,128
    Good stuff! Have you managed to fully test the cable?
  25. BADDY32
    BADDY32
    Feb 23, 2014
    How do you fully test it?
    It works with my sky and PS4.
    Do I need to do a separate test?
