Hi, i am new here, but have been reading a lot on these forums trying to plan out my setup. Unfortunately, the more i read, the more i get confused
. I am sure you've all read the same questions a hundred times, and my answer probably lies somewhere here on the first page, but PLEASE help me understand
. Also, please keep in mind that i am not an audio/video-phile, so i am not looking as much for a perfect quality, rather for most versatility/usability.
So, i am buying a 42' LCD (that's all i wanted in the beginning). Since i am going to fork out $900 for a 1080p TV, i might as well get a bluray player and 5.1 sound system (nothing fancy, just ability to put out 5.1 sound).
Here was my plan:
- 42' LCD
- Bluray player connected to LCD
- Reuse my existing computer 5.1 speakers and plug them into the bluray player.
- Connect my PC from another room to the LCD (not for quality video, but for control purposes), and the speakers connected to the PC's sound card, so i can listen to my MP3s (from my computer) while being in the main room
(Total cost ~ $1200)
But then i start reading these forums:
Bluray players needs to support audio decoding
Seperate sound amplifier
Home theater AVR
HDMI cable length restrictions/price
HDCP problems between video cards and monitors
Bluray software on PC's don't play back 5.1 sound (if i get a BD-ROM)
Now everything together is coming up to over $2000, plus a TV stand.... this is way over what i planned for.
I am more confused now then before i started
- Why can i not connect my PC's 5.1 speakers directly to the Bluray player? This is my main question. Why the need for all these special home-theater systems and seperate amplifiers and AVRs? I am not building a mini-theater in my room. All i need is to play 5.1 sound while watching movies with a few friends. Will i be strugling to hear sound from the speakers without the amplifier, or is the amplifier only needed to make the house shake? Don't most PC 5.1 speakers already have an amplifier in the subwoofer anyways? It's an appartment building, so it's not like i can crank it up anyways.
- Sound over HDMI. So i hear HDMI 1.3 supports sound and video on the same cable... but where does that fit into my system? I can connect HDMI from the bluray to the LCD, but the LCD only has 2 speakers. Is there an "out" HDMI from the LCD that then goes into the sound system? I haven't seen PC speakers with HDMI input, so can i use the Digital Audio Out (TOSLINK?) from the TV to the speakers, thus the sound will go from the bluray, via the TV, into the speakers, for full 5.1... right?
- PCI Express Sound Blaster X-Fi Titanium Fatal1ty Professional Series SB0886 - Sound Blaster - Get the Pro Gamer's Choice for Sound
What is the best way to connect my PC's sound card to the speakers that are about 50feet away? I already have a splitter cable for the 4 1/8" mini-jacks. What's the audio cable called that goes into these? And will it run 50 feet or will i lose all sound quality? I don't need crystal clear sound, but if it's going to have audible cracks/hissing, thats a problem. Is it better to run those 4 long cables, or get 1 TOSLINK cable for 50 feet (if my speakers have an optical in)? I asume TOSLINK can support 5.1 sound, right? I am looking at price here first.
- Most bluray players are ~ $250. I was considering maybe getting a BD-ROM drive for my computer instead (~ $150). Then i would need to connect my computer's DVI output to the HDMI on the TV thats 50feet away in another room. Is this feasible? I've seen some expensive 50feet DVI/HDMI cables, and i've seen some cheaper ones. I was also looking at "baluns" that can send this signal over cat5e/cat6 cables.
Once again, i found some of these quite expensive (around 300-500 range), and then i found these for only 130
Legend Balun Point-to-Point HDMI to CAT-5 1080i HDTV Extender [Balun HDMI to CAT-5] - $129.00 Canada : electronicsforless.ca : Always fast, always easy!
Does anyone have any experience with these? There are HDMI/HDMI baluns, and there are HDMI/DVI baluns (which seem much more expensive). Can i not have HDMI/HDMI baluns for the 50-feet length, and then use a regular HDMI/DVI cable on one end?
- How would my sound be processed if i have a BD-ROM? I thought i would get regular 5.1 from my soundcard, but apparently standard blu-ray player software that comes with these drives cannot reproduce 5.1. I'd have to pay extra to get the "pro" software (that's another ~ $80).
- Why do i need to connect the standalone blu-ray player to the home theater's AVR? I read in a few places that the players cannot decode the 5.1 sound, so they pass it to the AVRs for decoding? But on the player i was looking at, it says "TrueHD surround sound decoding"
Future Shop: TV & Video: Blu-ray Players: Samsung Blu-ray Disc Player (BDP1500)
So i don't need the AVR for decoding with this player, right?
- If i have the standalone blu-ray connected to the LCD, than my computer to LCD connection does not need to support 1080p. But i still want to get the biggest resolution (1024x780 is too small for a desktop). Can i get 1080i over the DVI/VGA connector or maybe component video?
- Finally, unrelated to these forums though, do wireless mice/keyboards have to point at the receiver? Or the can receiver be anywhere in the room? Also, will this wireless work through the walls? The total distance i need is about 25feet with an appartment wall in between.
Thank you all for the answers
Here was my plan:
- 42' LCD
Home theater AVR
