Please help me program my Telewest Di2000T cable tv
Discussion in 'Cable TV & Virgin Media TV' started by cameronl, Oct 3, 2004.
  1. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there, I'm trying to program the chanel changing of the Di2000T cable tv box but am unable to do so - the learning function just doesn't work on my MX-700 or RC5200.
    Does anyone out there know the discrete codes for the chanel up and down?
    thanks
    CaM
  2. AMc
    AMc
    Nov 20, 2000
    6,670
    Near Norwich
    +3,228
    Assuming that's a Pace box - you won't be able to. TeleWest use IRDA (like computers) not IR like more or less everything else in the lounge.
    The 4000 series Pace box will work with IR but you have to program codes - the TW remote outputs IRDA which your remote won't learn.
    You can also convert IR to IRDA using this device http://www.letsautomate.com/10923.cfm?
  3. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there, thanks for the info.
    I'll buy the redeye thing then :)
    CaM
