Please help me get my sub working
Discussion in 'Subwoofers' started by cameronl, Nov 30, 2003.
  1. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there, I have a stereo amp (A75+) connected to my AV amp (yammy 630).
    This works great for movies; however, the problem is when using stereo. If I connect my cd player to my stereo amp I dont get any base as it is connected to my av amp.
    If I connect my cd player to my av amp then all works fine, but I'd rather have it connected to my stereo amp for a purer signal.
    What can I do about this? I dont want to buy an add on unless i have too.
    There is a thread that explains how to do this - but this method doesn't seem to apply to my A75+
    i.e.
    Connect CD and front speakers to A22.
    Connect A22 preouts to 2011 CD input.
    the problem being with that is that my A75+ only has inputs?
    Please help
    thanks
    CaM
  2. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    If your sub has hi-level inputs you could connect them up to the stereo speaker terminals in parallel.
