Please help me forumers
Discussion in 'Blu-ray & DVD Players & Recorders' started by audioman, Jan 10, 2005.
  1. audioman
    audioman
    Hello to all
    First of all , sorry for my bad english :laugh:
    I am about to buy a DVD Recorder and I think I am hesitating between 2 models
    PIONEER 520H
    PANASONIC E95
    I wanted to ask just a simple question about the PIONEER
    I have been reading several reviews (internet, magazines ) saying that the PIONEER has BAD TUNER QUALITY
    Can you help me , those who bought this recorder , to confim those allegations or not
    Thank you very much PIONEER OWNERS
    :smashin:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    The European Pioneer range does have a very poor internal tuner. However this isn't a major concern as most users would record from external sources such as a Digital TV digibox - and from such sources the picture is reasonable although composite sources can be weak.
  3. audioman
    audioman
    Thanks Rasczak
    How can you explain that this problem is not so mentionned in AV FORUMS by forumers
    I 've got 4:3 analogic TV set , plugged with TV cable, do you think I could have a problem ? Thanks
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    It depends what country you are in as broadcasting standards vary. Whereabouts are you in the World?
  5. audioman
    audioman
    Paris FRANCE
    Secam mode here
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    I'm not sure - I have little experience with your broadcast quality/signal.
    When you say you are using TV cable do you mean you have a seperate digibox to connect to the DVD recorder? If so then the quality should NOT be an issue. If your referring to connecting by coaxial cable (RF) then it could be an issue - but as I have no experience with Secam broadcasting I wouldn't like to say one way or the other.
  7. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I can't see a difference when I switch between a Pioneer 420 and a Sony 32" TV both set to BBC1.
  8. audioman
    audioman
    ok thanks mate
    Is there anyone who can answer my questions about secam reception ?
  9. audioman
    audioman
    Thanks EDDYAD
    Could you be more precise , thank you very much
    :smashin:
  10. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    The 420 is connected to the TV by scart. The TV has RGB input cabability and the 420's output can be set to RGB, composite or s-video.
    1. With the 420 set to Composite video output to the TV:
    When I set the Pioneer 420 to channel 1 (BBC1 in the UK) and the Sony TV tuner to the same channel, then I cannot detect any difference in picture quality when switching between the TV's tuner and its AV inout from the 420.
    Also the TV has dual tuners and can show pictures from two sources side by side (but rather small :) ). So I can see both the output from the 420 and the TV's tuner at the same time. There is no visible difference.
    2. With the 420 set to RGB video output to the TV, the picture from the 420's tuner is significantly better than from the TV's inbuilt tuner. It seems that converting the 420's received signal to RGB improves on the TV's normal capability.
    3. Testing s-video means moving a scart at the back of the TV which is rather difficult but generally s-video is almost as good as RGB.
