  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
Please help me decide which video cable to buy...
M
MyMateJohn
Hi, I want the video cable that will offer me the best video quality possible and highest resolution.
I have a Leadtek 6800GT, in the specs* it says it can support a resolution upto 2048*[email protected] I also recently picked up a Eizo F931* 20" viewable CRT which in the specs* can support a resolution of 2048*[email protected]
The Leadtek has two DVI ports (dual DVI? Analogue/digital DVI? I don't know!). The Eizo has a VGA input and 5 BNC inputs.
What cabling do I need to achieve best picture quality and maximum resolution?
I've found some likely looking candidates here, please comment if you can:-
DVI to BNC
http://www.pccables.com/cgi-bin/orders6.cgi?action=Showitem&partno=00679
DVI to VGA
http://www.pccables.com/cgi-bin/orders6...tion=Showitem&id=ID728579&partno=00673
DVI to VGA adaptor, then using a simple VGA to VGA lead
http://www.pccables.com/cgi-bin/orders6...tion=Showitem&id=ID728579&partno=00676
Thanks in advance!
*Leadtek http://www.leadtek.com/3d_graphic/winfast_px6800_gttdh_1.html
*Eizo CRT http://www.eizo.com/support/discontinued/crt/f931.asp
K
Kramer
A regular VGA cable will suffice. You can also use a VGA-BNC(5) cable, sometimes preferred.
No real benefit in DVI > VGA or BNC as it'll just be analogue anyway, same as the VGA output.
I'd also suggest running at 1600x1200 max ;) .
:smoke:
M
MyMateJohn
Ok, so because its converted to analogue there's no problem with hitting the max res?
About 1600*1200, do you say that because 2048*1536 is too high for general use like browsing, etc.?
For viewing HDTV and upscaling, having access to 2048*1536 is nice, non?
