Please help me connect up my Sony Kv36fs76
Discussion in 'General TV Discussions Forum' started by groove, Oct 19, 2003.
  1. groove
    groove
    May 26, 2003
    494
    46
    +159
    Hi ,
    I wonder could anybody give me some advice on how to CORRECTLY connect up all my new gear when i arrices on Tuesday.
    I will have all the following to get working somehow . :)
    Sony Kv36fs76
    Sony DVP-NS730 DVD
    SOny
    Sky Plus box
    Xbox and PS2
    4 Quality ISOX scart leads
    3 IXOS Optical leads to connect to Marantz DTS amp
    Now from what ive read the TV has 4 scarts 2 of which are RGB.
    I really want my consoles to go in via RGB and ive got a good quality scart switch box to plug them both into so i can switch between them so using up 1 RGB scart.
    Thats where i lose the plot a little bit, dont think the family will be too impressed if its only my consoles that work........;)
    So I was wondering if somebody could point me in the right direction to getting all the wired up correctly including the RF aerial.
    I get so many opinions from people who think they know what they are doing i thought id ask you guys and get the correct way....
  2. Pug72
    Pug72
    May 10, 2003
    2,087
    Hereford
    +311
    HI.
    I am about to purchase the very same tv!
    (the 4 scarts[2RGB] clinched it for me.)
    I have Sky+ too and as I have no need for a VCR I plug my xbox into the sky+ box which will be in scart1. It passes through the RGB signal perfectly.
    My DVD will be going into scart2 and as I don't use my PS2 or Gamecube much, they will be in 3 and 4.
    I can through away my multi-scart box now!
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    In the interests of simplicity for other users why not use AV1&2 (that is the two rgb capable sockets according to the spec sheet i have in front of me) to accept an RGB signal from Sky and the Xbox and try an s-video signal from the dvd player (the drawback here is an unsightly cable going into the front of the tv however you can unplug it when not in use).
