Sfoley1
hello.
I am really struggling in working out what size screen I need. I've downloaded ProjectorPro but can't really make sense of it.
I have just bought a Benq W1110, should arrive next week.
I intend to buy a screen that will fit on the ceiling and pull down (budget £200).
The projector will be 350cm away from the screen but could be moved closer.
Seating will be 240cm away from the screen.
The room isn't particularly dark, we have decent curtains but they are not blackout and there is street lighting outside the house.
We have a through lounge and the screen will be between the two rooms, projector will be in front of the bay window.
My assumption was that I would have to have a 100" screen but I think this is too big for the distances I need to work with.
The more I try and work it out the more I get confused, doing my head in!
Any advice would be much appreciated, thank you.
