PLease help me choose a TV for my deaf daughter!!
Discussion in 'TVs' started by JohnC, Dec 14, 2003.
  1. JohnC
    JohnC
    Aug 12, 2003
    164
    Central England
    +4
    Please can anyone help?
    What's a good cheap TV... up to about a couple of hundred pounds that I can buy for my daughter who is deaf??
    Obviously the quality of sound doesn't matter but a good picture, teletext with reasonable size screen to be able to see subtitles is very important.
    Regards John
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    Hi John,
    If I was buying a tv with a budget of £200 or less, i would probably go for a Sony 21" set, such as the KV-21CT1.
    It isn't widescreen, but it does have a 16:9 mode, so dvd's can be watched at full resolution.
    If you want a bigger picture or you want a widescreen set, both are available for less than £200, but in quality terms you'll be hard pressed to find something that approaches the Sony within this price range.
    Cheers,
    Bob.
  3. Daglor
    Daglor
    Sep 21, 2003
    111
    16
    Chorley
    Toshiba 28N33.
    You can get them for about £239.99.
    Nice big crystal clear picture.
    I've PMed you details, check your user c.p..
  4. ronster
    ronster
    Dec 12, 2003
    27
    3
    +3
    John, perhaps you could look for a TV with strong bass - that way your daughter might be able to get some extra sensory feedback. Having said that, it might drive the rest of your household mad so you might need a sound-proof room!
  5. preston
    preston
    Feb 21, 2003
    138
    Preston
    The JVC AV28R25 has a built in sub which gives plenty of bass. Unfortunately it is just shy of £400.
    The back of the AV magazines usualy list the "best" budget TVs.
