Please help - LG32LB75, and connections
Discussion in 'LCD & LED LCD TVs Forum' started by glennuk1, Jan 23, 2008.
Tags:
  1. glennuk1
    glennuk1
    Jan 16, 2008
    443
    +7
    Hey basically just got a new hdtv tv (LG32LB75), and want to connect my xbox 360 to it.
    So i have the xbox pro, but not hdmi cable, however my av cable has the normal av plus 3 other inputs, red green and blue!
    My question is which ones do i use, my tv has 5 inputs, but with the normal 3 and the extra 3 which one do i leave out, i left the white out at first cos it wasn't on the colour coded inputs on the back, but then i had no sound, so i put the white in for a red one on the normal avcable and the sound is back.
    Just wandered if anyone could help!
    Also any general things that would help me, such as a good dvd player to get, mine currently is a region free dvd player, but is very old i don't know th emodel number but its about 4 years old, its a Lodos, i have heard about upscaling dvd players, and not 100% sure on what they are, but is it for hdtvs?
    Also what settings are best to use to get the best performace from my tv.
    BTW so far i am very impressed with it, it looks great :_Hey basically just got a new hdtv tv (LG32LB75), and want to connect my xbox 360 to it.
    Just wandered if anyopne could help :)
  2. kovacs
    kovacs
    Nov 14, 2007
    7
    3
    Oslo, Norway
    First of all, congrats on getting a great TV set. I've had this LCD since Christmas and it is excellent with SD signals and even my old, cheap Sony DVD player is treated well by it.
    Sounds to me like you do have the Xbox HD component cable...just connect it as the colors suggest and you should be fine...?
  3. Dr Zaius
    Dr Zaius
    Feb 12, 2006
    139
    +16
    Also remember to set the switch on the Xbox360 component cable to HDTV. Here is a link explaining how to connect using component:
    http://support.microsoft.com/kb/906303
    hope this helps
  4. glennuk1
    glennuk1
    Jan 16, 2008
    443
    +7
    Thanks guys,
    I Have a new problem, my remote control for the TV, doesn't have a text button, a tv guide button, or the red, blue, green, and yellow buttons, used fo tv text and digital text and some programs.
    Did i get the wrong remote, can i get a new remote or what should i do, i always use teletext and at the moment i can't, and where as a guide would be useful, i'm more bothered about not being able to use text!
  5. Dr Zaius
    Dr Zaius
    Feb 12, 2006
    139
    +16
  6. glennuk1
    glennuk1
    Jan 16, 2008
    443
    +7
    Hey also, as wondering, i currently have my dvd player hooked up and when im watching dvds, when it changes like camera angle or scene the backgroudn colour sort of dims then brightens and stuff like that, however if i watch the same dvd on my 360 the colour changes do not occur!
    Any ideas?
    I thought it may be because i am using an old scart lead for my dvd player, and the component leads for my 360! Could that be the case?
    or could it just be because my dvd player is old and crap?
  7. kovacs
    kovacs
    Nov 14, 2007
    7
    3
    Oslo, Norway
    I use an old and crappy Sony DVD via Scart on the LG and it's very good. I do have a good, shielded Scart cable though, might be exactly what you need.
  8. glennuk1
    glennuk1
    Jan 16, 2008
    443
    +7
    Also will an hdmi v 1.3 lead work even though the LG has hdmi v 1.2 ports? Anyone found the best settings for this tv yet?
  9. kovacs
    kovacs
    Nov 14, 2007
    7
    3
    Oslo, Norway
  10. glennuk1
    glennuk1
    Jan 16, 2008
    443
    +7
  11. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    you would be better off asking in the dvd/upscaling players forum, as this is taking the thread off topic...but for £30 it's worth taking a chance on.
    Curly
