please help installing dvd encore
Discussion in 'Desktop & Laptop Computers Forum' started by pat clancy, Oct 23, 2001.
  1. pat clancy
    pat clancy
    Sep 10, 2000
    1,820
    LONDON
    +29
    i installed the dvd rom,ok,and then putthe mpeg card in pci slot,connected the sound lead.but when i try to install the drivers etc,i ge the message,card not found,i assume it means the mpeg card.do i need to do anything else.
  2. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    pat are you sure you pushed the card fully into the socket?
    if so try going into start,settings,control panel,search for new hardware and let windows search for new hardware then install the mpeg drivers as when asked.
    hope this helps a little
    jason
  3. pat clancy
    pat clancy
    Sep 10, 2000
    1,820
    LONDON
    +29
    CHEERS JASON,I HAD TO INSTALL THE DRIVERS FROM :RUN;,OK NOW,I JUST NEED TO GET REMOTE WORKING
