Please help, I am seeing frame members thru Blackout Cloth
Discussion in 'Projectors, Screens & Video Processors' started by Jim McC, Sep 4, 2004.
  1. Jim McC
    Jim McC
    Mar 28, 2004
    64
    Wisconsin
    I just bought my first projector today(X1) and my wife and I started viewing Jurassic Park on the DIY B/O cloth screen I made. Frame is 52"X92" made out of 1X3 pine, 3 vertical inner members and each end. As soon as there was a sky shot, we could see the vertical frame members show up as stripes on screen. This was confirmed a couple more times before I shut off projector. What should I do now, put a second layer on it? Has this happened to anyone else? I sure could use some advice. Thanks.
  2. Zone
    Zone
    Jun 24, 2001
    6,792
    Barnsley
    +2,532
    Sounds as though the timber maybe hasn't been assembled square, just a guess obviously :blush:
    I take it you haven't attached a black border to the screen, if you did you would see a noticeable perceived improvement in contrast and this would also hide the problem you’re experiencing, just an idea :)
    Goodluck
  3. avanzato
    avanzato
    Jan 21, 2003
    1,969
    Norfolk
    +82
    Are you seeing the frame because it's touching the fabric and creating a 'bump' in the screen or is light shining through the fabric onto the members behind?
  4. Jim McC
    Jim McC
    Mar 28, 2004
    64
    Wisconsin
    It must be light shining thru the fabric. I wonder if there is more than 1 grade of B/O cloth and I bought the wrong stuff. Do you think I should put a second layer over it? It doesn't make sense to remove all the staples. Thanks.
  5. Zone
    Zone
    Jun 24, 2001
    6,792
    Barnsley
    +2,532
    I'm suprised light is shining through the fabric, it is meant to be Black Out material after all.
    Go for a second layer if you think that will do the trick, the fabrics cheap enough.
  6. avanzato
    avanzato
    Jan 21, 2003
    1,969
    Norfolk
    +82
    It's easy enough to test the fabric just hold it up to a daylight window, with your hand behind it, and can you see through. My screen material which isn't DIY has a black backing to the screen, I guess this is to absorb the light that shines through the white layer. Could you do something similar?
