please help i am going mad!!!!!
Discussion in 'Projectors, Screens & Video Processors' started by gingin, Mar 13, 2006.
  1. gingin
    gingin
    Jan 31, 2006
    165
    +11
    hello all
    i have just received my sanyo z4 projector.
    the problem is i started setting it up around 6pm, its now 10.35 and i am yet to see any thing on it!!!
    all i get is a blue screen with a box in the bottom left counting down.
    i am connecting a dvd cyberhome via component , i have selected component on the projector and the remote - nothing.
    i connected my old dvd player via video cable - selected video remote and projc=ector and still, blue screen..
    any help would be grateful
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    First connect the DVD player via plain old composite to a TV and make sure that within the menu of the DVD player, you have selected component output in the 'Video out' section (it may be set to RGB or S-Video) once that has been selected, then connect the component to your projector BEFORE turning the pj on. Now turn the pj on and it should lock onto the component signal. If not, turn off the dvd player and turn it on again.
    This should do the trick
  3. gingin
    gingin
    Jan 31, 2006
    165
    +11
    oh my god!!!!!!
    Oakleyspatz you are bloody amazing!, i have been reading that instruction booklet from cover to cover all night...
    problem sorted thanks a million....
  4. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
    Pleasure !!!
  5. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    lol. i've had so many problems like this with PC's :rolleyes:
    i find it quite odd that some hardware does'nt auto select if there's only one input (assuming that was the case).
  6. Darko
    Darko
    Apr 13, 2005
    4,226
    Caterham on the hill Surrey
    +223
    we all know these things cause we have all been where you are tonight,eccept we had to work it out (which sucs) thank god for av forums and the shared knowledge with in it.
    Darko
  7. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Tell me about it,it still pi**es me off that my z4 wont find the hdmi connection unless the pc is rebooted or the lead pulled out then plugged back in, apparently this is a hdmi issue and nothing to do with the Z4.
