Please Help! High Pitch Tone Feedback
Discussion in 'Plasma TVs Forum' started by rids666, Dec 22, 2006.
  1. rids666
    rids666
    Hi All,
    This problem is based around my newly purchased Panasonic TH 37PX60B Plasma TV.
    Since installing this i have had a high pitch audio tone through my speakers, which is not loud but definately present.
    I'll try and keep it to the basics:
    TV to Toshiba SD 360E DVD Player via HDMI.
    DVD Player to Denon 1707 Amp Via Digi Coax.
    Problem only happens with the Amp on (Obviously) and TV plugged in. If i unplug the TV or break the link from the TV in anyway then i get clear sound.
    This problem also happened with my Sony sky box using a scart and standard red and interconnects, but i got around this link by using an optical lead.
    I would have happily done the same with the DVD player however the 360e does not have optical out.:(
    I could just go out and buy a new DVD player but the toshiba is new and besides that i feel that surely i should be able to link my system with any of the available connections.
    I'm hoping that someone can help me. I've tried everything i can think of to try and eliminate the problem but no joy. I'ts really starting to get me down.:suicide:
    It does not do it with my portable tv and ive tried a different amp but still no joy HELP :lease:
  2. rids666
    rids666
    Hi all,
    I can't believe that i'm the only one to have had this problem.
    Any ideas would be helpfull please.
    Thanks in advance.
    Allan
  3. Frosties
    Frosties
    Dec 8, 2006
    3
    You may have a ground loop! If you take out the antenna is the sound gone? If yes, get a filter for the antenna cable.
