Please Help!!! Have I bought A hdtv
Discussion in 'LCD & LED LCD TVs Forum' started by gersrt, Apr 25, 2007.
Tags:
  1. gersrt
    gersrt
    Apr 25, 2007
    17
    Hi I purchase the below tv last week. No where in the documents does it mention that its hd ready but it does have the right connections i think.
    These are the specs
    Model Targa LT 3020
    Colors 16.7 million
    Max. resolution 1280 x 768 pixel
    OSD Easy-to-use graphical interface
    Teletext TOP/FLOF, 252 page memory
    TV-standards PAL/ SECAM BG, DK, H, I and SECAM L, L‘
    Input signals Aerial input
    SCART connector (RGB input, video /audio R/L)
    SCART connector (S-video, video / audio R/L)
    S-video / audio input R/L
    Video / audio input R/L
    2 x Component Video (Y/Pb/Pr) / audio input R/L
    DVI / audio input R/L (with HDCP decoding) VGA / audio input R/L
    Max. diagonal 75 cm / 16:9 aspect ratio
    Audio standards multi Stereo, NICAM and A2
    Audio data 2 x 7.5 Watt RMS, two-way loudspeakers
    Response time 16 ms TR + TF
    Contrast 600:1
    Brightness 550 cd/m2
    Viewing angle 85°/85°/85°/85° V/H
    Control elements Infrared remote control
    Basic functions controllable on device
    Important marks of conformity conformity CE
    Pixel error class: 13406-2 Class II
    Power Supply Internal power supply with mains switch
    Power consumption (On/Suspend/Off) 150W typical / < 2 Watt in Standby
    Type 30" LCD TV
    Measurements (WxHxD) 933 x 526 x 215 mm incl. stand
    Weight 15,3 Kg
    Highlights - DVI input
    - PAL Progressive Scan
    - Picture-in-picture function
    - Automatic channel search
    - Automatic channel sorting
    extensive scope of delivery
    • remote control with batteries
    • 4x video-adapter-cable
    • antenna cablel
    Thanks in advance
  2. Silver Serpent
    Silver Serpent
    Nov 17, 2006
    2,924
    +415
    Yes, the resolution suggests it's HD ready, however I see there is no HDMI input, which baffles me??
    It does however have 2 component inputs, which will carry and display a HD signal.
    Are you sure it has no HDMI?
  3. ic1male
    ic1male
    Dec 14, 2006
    28
    Seems to be HD-ready. Providing it meets the remainder of the requirements -
    HD capable inputs accept the following HD video formats:
    1280x720 @ 50 and 60Hz progressive scan (“720p”), and
    1920x1080 @ 50 and 60Hz interlaced (“1080i”)
    then it should be OK. You've got the 720p minimum pixels, DVI with HDCP input and 2 components.
  4. gersrt
    gersrt
    Apr 25, 2007
    17
    Yes defo no HDMI. I Think some older lcds didn't have them
  5. Duel
    Duel
    Nov 28, 2006
    2,562
    68
    +88
    DVI is as good as HDMI, providing it has full HDCP.
  6. Silver Serpent
    Silver Serpent
    Nov 17, 2006
    2,924
    +415
    That's a shame, as you can't hook up a PS3 or Sky HD box, plus various other sources directly.
    However, a component to HDMI adapter could solve your problem if one exists.
  7. ic1male
    ic1male
    Dec 14, 2006
    28
    Eh? The TV has got two component inputs - you can connect a games console to one of those and SkyHD to the other.
    EDIT: After reviewing the website, it appears this TV may not be HD-ready after all. It may simply be an SD widescreen TV and therefore can only accept a 576i/p input.
  8. MrLOL
    MrLOL
    Nov 13, 2005
    403
    28
    Wakefield
    +31
    its not HD ready
    it has to have a HDMI port to be HD ready. It has however a HD telly, as it supports HDCP over DVI and has a resolution capable of displaying HD footage
    DVI also isnt capable of carrying audio, so your not going to be able to get sound on the TV from anything you connect up, unless you use the component input, so its a bit pointless
  9. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    Wrong info, sorry.
  10. andyUK101
    andyUK101
    Dec 30, 2006
    1,708
    83
    +456
    Not strictly speaking true, the EICTA guidelines state a tv must have either HDMI or DVI (assuming both are HDCP compliant) Also component doesnt carry sound either which is why the spec list mentions R/L audio input for both component connections
    Both the HDMI/DVI and the Component connection also have to accept HD signals
  11. andyUK101
    andyUK101
    Dec 30, 2006
    1,708
    83
    +456
    Just noticed the "Class 2" part of the specs, be prepared for dead pixels when it arrives, of course you may strike lucky and have non but as they mention its a class 2 product i doubt they will accept returns on it for dead pixels
    IIRC class 2 products can have upto 3 or 4 dead pixels screens of that resolution
  12. Silver Serpent
    Silver Serpent
    Nov 17, 2006
    2,924
    +415
    Does Sky HD have component out?
    I thought it was HDMI ony?
