Please Help Guys
toycollector
Hi All
just had SKy Broadband and its fine.On small problem.I have an email account with freeuk.I can receive from them ok.When i try to send, it fails. I presume i need to change the account from my previous talktalk account but to Skys. tried talking to Skys tech guy somewhere in asia but he was clueless.HEEELLLLPPP!!!!
madman1178
can you not go into the email setting for sky and copy the outgoing smtp details.
or try searching google or sky for their outgoing email settings (smtp) and simply put them in the smtp box for freeuk
williemaykit
You will be able to pull your email from FreeUK but unless Sky allows relaying, then you will not be able to send emails from your freeUK account using Sky's outgoing (smtp) mail server. Check with Sky on this. FreeUK or your previous ISP will not allow you to use their SMTP server because you are not their network. Again check with your ISP.
