Please Help Finalising a disk
Discussion in 'Blu-ray & DVD Players & Recorders' started by Marfun, Jan 27, 2005.
  1. Marfun
    Marfun
    Hi Everyone i hope that someone out there can help me. If you have recorded some dvd disks on a stand alone DVD recorder and had not finalised them and then the DVD recorder broke, If you then bought the exact same make and model DVD recorder as before would you be able to then finalise the previous discs even though they had been recorded before on the machine that broke which was the same make and model as the new one Please help !
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Yeah that should work
  3. Marfun
    Marfun
    ok Thanks what if i were to try finalising the discs on a different make and model of DVD recorder would they finalise them ( i realise that they would not play them but i am wondering if they would be able to finalise them )
