Please Help! Denon 2805 & Component Video
Discussion in 'AV Receivers & Amplifiers' started by alexcord, Oct 16, 2004.
Tags:
  1. alexcord
    alexcord
    Sep 15, 2004
    79
    I have recently purchased a Denon 2805 amp. I am currently using it purely for audio processing but have just realised that I have component inputs in my Toshiba 36 Picture Frame.
    I was just wondering if there would be a noticable difference if I start using the Denon amp for the video as well as audio.
    I currently use scarts to connect Sky+ through a Philips DVD R70 recorder (no component outs by the way) to my Tv.
    Can I get leads relevant leads ie RGB to Component etc. I am a bit of a newbie regarding the component side of things so please excuse me if it was a completely daft question.
    Many thanks for any advice.
    Alex
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    doubtful you would see much improvment as you would just have to convert the RGB signals to Component...
  3. TheeNoMaD
    TheeNoMaD
    You could get an RGB scart to s video and then convert it that way i think.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    true but pointless..... unless you have a PD30
  5. alexcord
    alexcord
    Sep 15, 2004
    79
    So there is not point in using an S-Video out of Sky+ into the Denon over RGB straight to tv??
    Alex
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    RGB to TV is best bet mate
    Use a quality scart lead and bobs your mothers brother
  7. TheeNoMaD
    TheeNoMaD
    Bob really is my mothers brother! and you are right it is pointless him doing it but he asked if he could do it.
    Also i recommend a decent rgb only wired scart cable dont go over the top but a decent one helps. I have the rgb squart by QED improvements i found were in the movement of objects (like footballs) and the colours became much more vivid.
  8. alexcord
    alexcord
    Sep 15, 2004
    79
    Thanks guys, will stick with the scarts and RGB.
    Alex
