I had BenQ w1080st that was awesome. Id say there are newer versions now. I think Sony have the best 1080p pj picture wise because they dont suffer from a light wheel spinning and causing RBE. But I never had that problem. But then again they dont have a short throw. I think acer just made some awesome predator gaming pj but its expensive.
I think I was getting 100" @ 5 feet from the wall with the w1080st. Projectorcentral.com is good for calculating screen sizes for specific projectors.How short do you need the throw to be, as this is a big stumbling block?
I currently have the benq w2000 and getting 106"ish from about 2.5mish
how was the fan noise on that model? some reviews mention the fan to be quite loud.
Im not sure whats out there now but mate it was night and day the difference and Id even say the quality of the product and lenses were better on the Benq. Im no fanboy Ive owned 4 PJs all different brands and tested a few on top of that and Id have Optoma at the bottom of my list. Not sure if I said it before in a post earlier but I too need a pj in that price range for gaming and my first stop will be Benq.thanks all, i will look into the Benq models.
