It's not saying the drivers are missing just need updates but dxdiag shows
Display memory (vram) 241MB
The sound works so it's just the issue of the gfx not working properly.
EDIT
there was a setting in bios I had to change
Settings/advanced/integrated graphics configuration
Uma frame buffer size change from 256M to 2G
But now it's showing I only have 6gb of ram instead of 8gb, can you tell I'm in over my head lol is that because I upped the gfx?
EDIT
what do you think that setting you changed in the BIOS does?
you are using integrated graphics.
you have now allocated 2GB of RAM for graphics instead of 256MB. so that is why you are now showing as 6GB of RAM. because the integrated GPU now has taken over the 2GB for it to use exclusively.
the reason for errors will be due to lack of VRAM which you have now increased.
you really need a dedicated GPU for proper gaming. also 2GB of VRAM and 8GB of memory isn't enough for AAA titles.
he will be able to play optimised games well as well as older titles.
the 2GB of VRAM will struggle especially since it's DDR, GPU's usually use a much faster ram called GDDR
I don't think the integrated graphics memory scales to what it's doing. It just takes what's designated from the overall ram leaving you with 6gb for everything else.
After all the hassle you had I ended up buying a pre built with the 2400G. For my needs I'm impressed the just released Surviving Mars game is running at 1080p high settings and around 60fps.
They already have both which makes the pc kind of redundant in my opinion, I only built it to save my cousin money. Now it's running it's quite impressive but still not worth the headache lol.I'm going to be very controversial here but since Fortnite has crossplay, how about your cousin gets his son a PS4 Pro/Xbox One X?
I didn't, I was so relieved it was done I boxed it up, they haven't collected it yet so I might set it up later and have a look. I'm new to gaming PC's so excuse my lack of knowledge, is 3dmark a program and do I just install it and then run a game?Did you manage to run any 3Dmark's before offloading it onto your cousin ?
