Please Explain Native Resolution
Discussion in 'Projectors, Screens & Video Processors' started by nheather, Sep 6, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    17,278
    167
    Horsham, West Sussex
    +6,581
    Several posts have expressed disappointment that the majority of panels (including the Panny PHD7 and PHD8) do not support native resolution at 50Hz.
    If I take a 42" PHD7 as an example, the panel is 1024 x 768, which I assume is the native resolution.
    I can understand that it is desirable to be able to use a scaler to feed the panel with 1024x768 image and that to avoid frame rate conversion it would be best if the panel accepted a 50Hz signal.
    So the disappointment that the panel doesn't accept native resolution at 50Hz makes perfect sense.
    Then I became confused because a number of experienced posters stated that the Panny panels will accept PC signals at virtually any rate you want to throw at it, even those not declared in manual. They suggested that you can feed the PC terminal with 1024x768@50Hz and the panel will display it without problem.
    This is my confusion ....
    What is the difference between
    (a) Native resolution - 1024x768@50Hz
    (b) PC - 1024x768@50Hz
    Thanks for the help.
    Cheers,
    Nigel
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,570
    The Borders
    +3,029
    Hello Nigel
    The problem being the inability to accept the Native pixel count in a Digital format - you can often do it on Analogue as RGBHV but your just as likely to be snookered if your working with a Digital RGB or YUV signal from an HDMI or DVI (with HDCP) equipped SD or HD source.
    As many of the current external Video Processor's have high quality Analogue to Digital conversion for your legacy sources plus Digital Inputs for SD and HD sources and Digital outputs with programmable pixel and refresh clocks a lot of folk look to have an all Digital signal path between the Video Processor and the Display.
    Best regards
    Joe
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    ...via a digital connection such as DVI or HDMI, whereas these same panels accept native resolution at 50Hz via analogue connections such as VGA.
    It's all to do with the model of DVI Receiver chip that the manufacturer sourced for their display, the older ones only accepted 60Hz.
    StooMonster
