Please excuse my ignorance..........
Discussion in 'Plasma TVs Forum' started by GedF, May 23, 2005.
  1. GedF
    GedF
    but what does calibrate mean in relation to a plasma screen. How does one calibrate a plasma?
  2. Mep
    Mep
    Dec 25, 2004
    9,604
    Surrey
    +476
    Ged look here....www.homecinemaengineering.com you can do some basic stuff yourself but you need a qualified expert like Piers to do it all properly.
  3. GedF
    GedF
    Thanks MEP - I assume some plasmas are easier to calibrate than others? How does the Viera stand in this department?
  4. Mep
    Mep
    Dec 25, 2004
    9,604
    Surrey
    +476
    I don't have a viera but I do have Panasonic panels and Piers gets great results with them......
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Veira is a bloody nightmare but i am sure piers will do it for you, dont ask him for a discount tho!
  6. music
    music
    Mar 25, 2005
    518
    +14
    the cost of calibration would be 25% of the purchase price of my panny - is that really worth it in terms of proportionality?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    if a screen that looked significantly better and was availbale with exactly same specs as your panny would you have bought it?
    what if cost 25% more?
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    The ISF is £250, did you get a second hand viera for £1000?
    I am going to get my Viera done when I get one next month and have run it in for a hundered hours or so. Everyone says it is worth it that has had it done - just get it done when you can afford it, treat it as a 'upgrade'.
  9. GedF
    GedF
    So you need to run the screen for @ 100 hours before having it calibrated? Again, excuse my ignorance, but why is that?
  10. Pat Marcus
    Pat Marcus
    Oct 29, 2004
    610
    Ibstock
    +8
    I`ll add my voice to meps. Definitely worth having it done. Even if the cost is 1/3 the total you paid for your screen. The difference is, as Horny has intimated, tantamount to having a whole new, even better screen.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    the huindred houirs is to allow the screen to wear in and bed down, and if its going tits up its in the first 100 hours so best not spend £250 on a screen and have go pop an hour later!
  12. GedF
    GedF
    Thanks - these plasmas sound more like bleedin' cars than televisions!!
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    nope just like any high performance item the require expert attention.
