please delete
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by LWells, Aug 27, 2018.
  1. LWells
    LWells
    Feb 16, 2004
    96
    11
    Midlands
    +9
    Looking for some opinions on the slimline amps or more specifically the Marantz 1508 as I have seen that this is on offer for about £250, I have an old Yamaha 757se which is many years old! in my 5.1 lounge setup but it doesn't fit on the shelf below the TV so I fancy getting a small receiver.
    It needs to power Kef IQ5,IQ6c and Some 3001 egg rears, I know its only 5.1 but wont have more than this in the lounge at any time, I am setting up a cinema room so that will get a decent amp and atmos etc at a later date.
    OR the smaller Yamaha amps would JUST fit as they are 161mm high … so would I be better getting say a Yamaha RX-V481D which again is only £250, the shelf is 164mm high.
    any opinions would be great, the Marantz would fit the best but is it any good and powerful enough or do I just get a cheap Yamaha?
    thanks
