F
foxyjo
Hi from a newbie
I am absolutely desperate and have millions of pieces of paper scattered everywhere, in an attempt to find the perfect set of 'components'.
What I want seems quite simple, but I'm finding it hard to narrow all the various items down to the easiest and simplest set-up.
This is what I'm looking for:
DVD Recorder (preferably not the very cheap end)
Hard drive - something that will record about 40hrs
Freeview box which receives DAB, EPG, has twin tuners and 2 Scarts
I've looked at just about everything there is on the market, and even considered the Topfield TF5800 (I think it's called), but that seems too technical for me at the moment.
I've also checked out the Sony RDR-HX(D?)710, as it does everything I want except it doesn't have twin tuners (1 digital and 1 analogue), nor does it receive DAB.
Total budget between £300 & £400. The cheapest combination I've found seems to be a PVR with separate DVD Recorder, but I really am confused and need a bit of guidance by someone who knows their stuff.
Anyone able to help?
Many thanks.
Many thanks.
