Please can someone advise me?
Discussion in 'PS Vita Forum' started by nofear01, Jan 17, 2008.
Tags:
  1. nofear01
    nofear01
    Apr 21, 2006
    2,148
    3
    +86
    I am about to go pickup a Jap PSP (original) for £50
    What I want to know is:
    1) Can I flash this firmware myself?
    2) Will this play UK games?
    3) Can I connect this to my PS3?
    Thanks in advance guys
    x x x
  2. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    You can load custom firmware on it, we’re currently on version 3.80M33 version 4
    With CFW on it will play games from any region either from UMD or memory stick
    With CFW 3.80 you can connect it to your PS3 for remote play
  3. nofear01
    nofear01
    Apr 21, 2006
    2,148
    3
    +86
    Thanks for your quick reply mate!!!!!
    I guess it is just a case of 'searching' all these threads on how to upgrade my firmware
  4. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    try this
    The Universal Un-bricker Easy Installer will create a magic memory stick with dark_alex’s universal un-bricker software for fat and slim PSP’s
    With a Pandora battery it will flash any PSP from any region be it slim or fat with CFW 3.71M33 version 2, this can then be easily upgraded to 3.80M33
    I removed the link as there could be possible copyright issues
    Installation Intructions
    • Unpack the file to a safe location
    • Format your memory stick via the PSP’s XMB
    • Connect PSP to PC via USB
    • Delete ALL files and folders from the memory stick
    • Run the installer (autorun.exe)
    • Follow the installers instructions its as simple as 1, 2, 3, 4
    • Finished!
    You now have a magic memory stick
    You will then require a Pandora battery, if you have a friend with a Fat PSP already running CFW they could create one for you using the stick you’ve just created or they’re are a number of options available off the shelf that provide the same function
    http://www.gameseek.co.uk/pd/PSPvy3xuhcnzhh/Battery-Service-Tool-for-Standard-+-Slim-PSP this device changes your existing battery to service mode and back again or
    http://www.divineo.co.uk/cgi-bin/div...p-hotwire.html to create a temp Pandora battery with AAA batteries or
    http://www.amazon.co.uk/Max-Power-T..._sr_1?ie=UTF8&s=gateway&qid=1200612639&sr=8-1 this is a pre made Pandora battery from Datel
    All these will work in both fat and slim PSP’s
    To use your Pandora kit
    Ensure the PSP is fully switched off
    Insert Memory Stick into the PSP
    Remove the external power if connected and insert the Pandora Battery into the PSP holding it in place the PSP boots and a menu appears like this
    - Press X to install 3.71M33.
    - Press O to install original 3.71 (rest of the process as the X option)
    - Press [] to dump nand to nand-dump.bin. When done, psp will auto shutdown.
    - Press L+R+HOME+start to restore nand from nand-dump.bin
    Press x and it will begin the installation, normally takes about 30 – 40 seconds
    When complete press x and the PSP will shut down
    Now replace with a standard battery and switch on
    If you get a blue screen don’t worry just press ‘O’ and it will reboot and that’s it
  5. nofear01
    nofear01
    Apr 21, 2006
    2,148
    3
    +86
    I am seriously new to PSP, can you recommend a decent memory stick, or is there a site that can do this?
  6. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
  7. nofear01
    nofear01
    Apr 21, 2006
    2,148
    3
    +86
    I want a big memory as I will put some films on it for when I go away.
    I am far too scared to do this on my own, so I am probably going to send this away to be flashed.
    I only wish there were shops that did it!
  8. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
    Don’t do anything just yet; I’m putting together a kit and instruction to loan out to people so they can do it themselves.
    I’ve just tested the easy installed on my 3.80m33-2 and downgraded it to 3.71m33-2 it worked fine no issues
    Play have a 4GB stick for about £28 delivered, I’d stay away from eBay if I were you
