Playstation2 Vs DVD Region X
Discussion in 'Blu-ray & DVD Players & Recorders' started by fishyben, Sep 8, 2001.
  1. fishyben
    fishyben
    If you've got a PS2 then you obviousley have some money, so i'd buy a PROPER dvd and not something that pretends to be one. There are alot of budget players out there (£100-£150) that have no trouble with RCE discs, it will save you pulling your hair out when every other disc you put in wont work.<br />Buy a budget player and use the PS2 for it's primary purpose 'games' .
  2. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    I already own A dedicated region 1 player which is great but people knock the PS2 for DVD playback when it's as good as My region 2 Sony 735 dvd player.All you need is to connect via component av which I have connected to my Toshiba 36zp18p No PROBS.My knock was with Sony for there software update giving the RCE world map,making the DVD region X that many people have paid £20 for not work.<br />So if you wanna buy the offical Sony sexy DVD remote note that you can't use it with out installing the software first,then you can't playback r1 titles. SONY BIG BROTHER<br />Oh ben i do have a few quid but always spend it on AV-GEAR So SHOW ME THE MONEY!............ <img src="biggrin.gif" border="0">
  3. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    Just come back from my local store with the very smart 'n'sexy new offical Sony PS2 Remote which includes the DVD player Version 2.10 software.Flipped in the cd saved the v 2.10 to memory card, put in my region x cd then my region 1 movie only to get the RCE world map.Thanks sony,<br />any one know if there is a crack for the new software as you can not use the dvd remote without the v 2.10 software.
    BIG BROTHER IS WATCHING YOU DVD REGION X
  4. stevemoss
    stevemoss
    Jul 15, 2000
    7
    Wigan , UK
    I know it's a bit late as you've already bought the Sony remote but I have Region X & joytects mini remote for my PS2 and they work fine together without you having to upgrade to Sony's new DVD software
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,746
    +2,719
    I am after using the PS2 as a R2 only player for a second TV in the house ( already have a multi-region player and an r1 only machine ) and was interested in the region X thing as it supposedly stops the green screen RGB thing.
    However for the above to happen do you have to play the CD b4 putting in your DVD or will the green screen be banished once the cd is run for the first time ?
    If not then I suppose it will be better just to use s/video connector
  6. Guest
    DVD Region X will get rid of the RGB green mask on the PS2. You need to enter some codes that you can get from here, along with instructions.
    <a href="http://www.dvdregionx.com/english/x_key_codes.htm" target="_blank">http://www.dvdregionx.com/english/x_key_codes.htm</a>
    Once you entered the codes the they are stored on the Region X dongle that goes into one of the memory card slots, or on the momory card itself if you have the latest version of Region X, so you only have to do this once. However you DO need to load the Region X CD first, everytime you want to play a DVD without the green mask, even for R2.
    They now have codes for the version 2.10 DVD player (that the Sony remote control software updates the PS2 to), if you are using one. I got the Sony remote at the weekend, and I've had no problems once I entered the codes for the new version DVD player. One thing to note though, is that even though the remote software updates the dvd player version, when you load the Region X CD, it still show's the old version number in the corner of the screen. Ignore this, and make sure you enter the codes for the new one - they are listed under "Euro Remote" on the web page.
    I've played R1 copies of Hannibal and Leon - Directors Cut so far, and not had any sign of a RCE world map. I don't know if this is because these aren't RCE protected discs, or because the new codes take that off as well as the green mask, so I don't know whether this will help with the original question on this thread, but it may be worth a go if you've not tried it allready.
  7. Juzminator
    Juzminator
    Mar 28, 2001
    346
    Ipswich,England
    Apparently, these are the new codes:
    E79A9A5F 83B731E3<br />E7979617 83BC31E3<br />679522DB 67B551D0<br />6795FE53 67B551D0
    I don't have a DVD Region X, but I've heard that these codes do the trick with the new drivers...hope this helps.
  8. cycomiko
    cycomiko
    Thanks to everyone for the information on this thread.
    I`ve added the codes for the new DVD version software included with the Sony remote and they work a treat.
    Just a couple of points:<br />1. The DVD playback on the PS2 is as good as my dedicated player when outputting RGB.<br />2. The new software included with the Sony remote enables certain trickplay functions not previously available eg Repeat A-B, along with one touch access to menus etc
  9. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    [ 16-09-2001: Message edited by: dts borg ]</p>
  10. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    Thanks for adding to my original post.Great what can be achieved
    BIG BROTHER SONY CAN BE DEFEATED.......... <img src="tongue.gif" border="0">
