Playstation2 on Philips 32PW9527
Discussion in 'General TV Discussions Forum' started by roboldham, Dec 24, 2002.
  1. roboldham
    roboldham
    Just in case anyone wanted to know in the future:
    If you plan to use a PS2 on the above TV - make sure you get an RGB Scart cable for your console.
    THEN run in through either EXT1 or EXT3 (NOT EXT2 as this will give artifacting and digital noise around detail, no matter what settings you have the TV set to)
    This is cos EXT2 is CVBS (composite) and Y/C (S-video) and the other two are CVBS and RGB
    I found good settings (maybe not the best, still playing) to be Active Control OFF and playing around with Sharpness.
    Hope that helps!
    R
