That's because the server was down for upgrade in the afternoon. It was fine in the evening.Thought would have a look, but locks up the PS3 on the initialising screen, have to power PS3 off to recover
Home need a repair man it seems
Anyone else tried 1.3?
Must be down again then as I did the upgrade about an hour ago and it still currently doing the same, will have to try later.That's because the server was down for upgrade in the afternoon. It was fine in the evening.![]()
same problem as the guy above .... i just upgraded to new version of home firmware and now i cant get passed a stuck initialising screenThat's because the server was down for upgrade in the afternoon. It was fine in the evening.![]()
well i just upgraded to 1.3 just now and it does exactly the same as you described ? and its 17th October now ? ?Thought would have a look, but locks up the PS3 on the initialising screen, have to power PS3 off to recover
i personaly think that the xmb should be Home itself ie once you switch on your ps3 u get put inside your crib so to speak where you can access your ps3 settings etcI had the same issue - just hanging and freezing the console at the start screen after updating to 1.3
The fix is to delete and re-install. Some users have had to delete both home and their settings file before it will work.
The actual home download is only 48mb so it isn't too much of a problem.
The problem i found having deleted and reinstalled was that although there were a number of new areas there since i last logged on i was still bored of it within about 10 mins
So the good news is you can get it working again pretty easily - the bad news is it probably isn't worth the effort![]()
