Playstation 3 + Sony Bravia
Discussion in 'Home Cinema Buying & Building' started by mthompson, May 8, 2007.
  1. mthompson
    mthompson
    Nov 16, 2006
    Dublin
    Having recently took staock of the Sony 40w2000, Im looking to connect it up with a good sound system and hopefully a PS3.
    What is the best home cinema system to connect the 40w2000, my old JVC XVN33 and a PS3 (to start with) Im also getting Sky HD in the next few weeks. Have a budget of about 600-700, but can be convinced otherwise.
    Really want to get some HD content into this TV and want the best sound set up to show it off !!:lease: :lease:
  2. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    If you want the best sound then - in my opinion anyway - you need to be looking at separates.
    This is a decent deal for separates at £800 - CLICKY.
    If you really want to feed your panel with HD content then spend another £250 on a Toshiba HD-E1 HDDVD player - CLICKY.
