Playstation 3 Connection Question
Discussion in 'Playstation Forums' started by AndrewP84, Mar 16, 2006.
  1. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
  2. dvdric
    dvdric
    Apr 6, 2002
    243
    ENGLAND
    +4
    Someone correct if im wrong but the dvi socket you have is the same as hdmi because on my hdtv it says hdmi and dvi on the same socket
  3. tazpc
    tazpc
    Jul 13, 2002
    252
    NORTH BUCKS
    +4
    Not the same.
    DVI is a much larger socket/plug but you can get an adaptor or a lead which will do HDMI-->DVI.
  4. Mark_a
    Mark_a
    May 27, 2005
    3,256
    +709
    HDMI carries the same video feeds as DVI but also includes digital audio that DVI doesn't. It's the reason you can get a simple, cheap adaptor. All it's doing is passing the signals through to the appropriate socket type, but you'll still have to feed your audio elsewhere (which isn't usually a problem if you're using an A/V amp anyway).
    On the other hand, DVI is also capable of carrying a full set of additional analogue video feeds (though it may not) hence the reason you can get cheap DVI to VGA adaptors. They too are just passing the analogue signals through to the appropriate socket type and ignoring all the digital stuff.
    Regards
    Mark
  5. Pooon
    Pooon
    Dec 26, 2002
    7,542
    Canterbury, Kent
    +1,185
    In laymans terms just buy a cable that has HDMI on one end, which you plus into your PS3, and on the other end of the lead it has DVI-I socket on it. They are readily available in all good stores that sell 'proper' cables
  6. dvdric
    dvdric
    Apr 6, 2002
    243
    ENGLAND
    +4
  7. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    If I do that, how will I connect the audio for the PS3?
  8. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    hasn't the ps3 got digital audio out? if so just a case of using that to plug into your amp
  9. Pooon
    Pooon
    Dec 26, 2002
    7,542
    Canterbury, Kent
    +1,185
    What eternaldark says is correct. But if you don't have a amp to plaug it into(doubtful but might not have) Sony will need to provide some sort of analogue output
  10. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    Checked the official specifications, and yes the PS3 will have a digital audio output.:thumbsup:
  11. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    I dont have any sort of amp :(.
    Looks like I am going to be a bit stuffed for audio.
  12. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    http://www.trianglecables.com/pof-733.html
    Would one of these work?
    As I only have a DVI-I Audio In port I was hoping I could just use some form of adaptor if I bought a optical cable lead and then plugged that into the above adaptor and then into my tv would I get sound or not?
  13. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    not sure if that will be any good or not, but you can pick up budget surround speakers with amps that will have a digital audio connection, and trust me will make the experience with games and movies that much better.
  14. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    Surely the PS3 will support Component?
  15. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    Yes. Has 2 HDMI ports, and multi AV out for analogue signals. By the look of it, AV out is compatible with existing PS2 leads...
  16. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    would expect so, but component doesn't carry audio either, so either sony will release a cable that will have 2 phono sockets for sound as well, or again you'll need an optical sound connection.
  17. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
  18. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    Yep that would do the trick, but at the moment I don't know if PS2 accessories will work with the PS3
    But sure something like that will be available at launch
  19. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    Just the same as the official component lead. RGB connection for video, red and white connectors for stereo audio (or Pro Logic 2 if you have the appropriate receiver).
  20. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    Hi All,
    It looks like my TV will support a HDMI to DVI converter but I am just wondering what I could use to get sound I dont really want to buy an amp or anything would just rather use my TV's speakers.
    Would I be able to use phono leads or something?
    Andrew
  21. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,531
    Yeovil
    +418
    I wouldn't worry mate, im sure sony aint daft enough to flog a console that only a few have the tv needed to play on it.
  22. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    Unfortunately I cant see any connections such as DVI which is the only HD Connection my TV has. I guess the original component cable could work but not confirmed by Sony.
    Also does anyone know if a DVI-D cable will work with a DVI-I socket on a TV as the only HDMI to DVI cables I can find are all with DVI-D on the end.
    Not looking good :(.
  23. Mickus
    Mickus
    Jul 11, 2005
    3,071
    South East Kent
    +332
  24. Noggin1980
    Noggin1980
    Aug 2, 2005
    6,821
    +1,175
    I'd be very surprised if the playstation 3 allows you to use old periphrals. Sony will be making a big loss on each console sold and cables, controllers etc etc are a great place to make some of that money back. Thats certainly the model that MS followed, I'd expect Sony to do the same.
  25. Mickus
    Mickus
    Jul 11, 2005
    3,071
    South East Kent
    +332
    I see no reason why you can't use existing cables. The PS3 has an 'AV out' as per the PS2. Though I suspect that it won't support HD via this connection type.
  26. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    From PS1 to PS2 though, you could use your existing kit, such as pads, AV leads, etc. The prototype model of PS3 clearly shows an AV out that is exactly the same connection as that on PS1/PS2. In that sense alone, they have been really good. Nintendo do the same to be honest. Since the SNES, AV connector has been the same...
    Bodes well in my opinion. :thumbsup:
    PS2 supports progressive scan, and GT4 supports 1080i, so I see absolutley no reason as to why 720p/1080i will not be supported through existing component leads.Let's face it, component is what you get as standard with Xbox 360 Premium pack. Never know, component as standard for the PS3 with option to buy your own choice HDMI cable sounds cool to me. Long have I waited for a console manufacturer to allow the user to use proper quality cabling instead of the cheap bits of plastic supplied.
  27. jedi-jae
    jedi-jae
    Sep 23, 2005
    586
    +11
    To Original Poster: here's a solution, but I can't be certain it will work!
    Use an HDMI - DVI cable for image
    Use the standard playstation cable, that is likely to be in the box, for audio as it should have the stereo cables for you to connect to your tv.
    Personally I can't believe there won't be others in your position, so it is almost certain that a cable will be made by someone that will allow you to use DVI and sound into your tv.
  28. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    Hopefully Sony will include a Component Cable with the PS3 :).
  29. AndrewP84
    AndrewP84
    May 30, 2005
    1,543
    Essex
    +28
    Any news on any phono audio leads? :)
  30. RunDMC
    RunDMC
    Dec 17, 2005
    624
    28
    Glasgow
    +36
    I hope that this is the case (and the fact that there are so many HDTVs in the US without HDMI is encouraging for this outcome). I also hope, like the Xbox 360, that PS3 will also support HD options over VGA.
