Playstation 2 v DVD player
Discussion in 'Nintendo Forums' started by Keithhampson, May 3, 2005.
  1. Keithhampson
    Keithhampson
    Apr 22, 2005
    674
    +6
    Hi I have a ps2 and I'm getting a dvd remote for it, I wondered if this as good as a DVD player or does it lack something, I know DVD players start at around £30 but is it really worth buying one if I have a ps2?
    Keith
  2. Pooon
    Pooon
    Dec 26, 2002
    7,350
    Canterbury, Kent
    +940
    The PS2, for want of a stronger word, pish as a DVD player. But then again so are £30 DVD players so don't get one of them either. Toshiba do a very well regarded player for about £80 from Richer Sounds, check the DVD player forum for what model it is as i can't recall off hand.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Stay away from the PS2 - it’s a very poor excuse for a dvd player. The Toshiba that Steve mentioned would be a much better bet.
  4. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Yep the PS2 DVD playback is a token feature. Even a normal quality dedicated DVD player beats it easily.
  5. jenic
    jenic
    Dec 10, 2004
    2,904
    83
    +180
    The PS2 dvd player is appauling but woolworths sell a good philips for around £45.
  6. voda
    voda
    May 4, 2005
    4
    leamington spa
    its rubbish
  7. Kila Skila
    Kila Skila
    Mar 27, 2005
    134
    Devon, United Kingdom
    +3
    If you can run you Ps2 through component then id say its worth doing if not then yeah go for a proper dvd player.
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,864
    Galactica C.I.C.
    +279
    the very first ps2s also suffered from sound sinc problems with dvd playback as well. :eek:
  9. crunchman
    crunchman
    Jan 22, 2005
    779
    North Wales
    +61
    Yes thats true :mad: reallly bloody irratating until I got a dedicated player :clap:
  10. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,369
    Yeah the PS2 DVD player isn't worth bothering with. The X-Box one is OK though. Personally i'd say go for the Pioneer DV575 for £99. That's a superb DVD player for the price with prog scan output and div x compatability! :thumbsup:
  11. fdxd
    fdxd
    What about PS2 on component? It gives the option. Does it do progressive scan?
    So far its not that great since it dont work on the RGB scart. The new slimline has had the bugs sorted at least.
  12. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,369
    Nope there's no prog scan from the PS2 DVD output as far as i'm aware. The X-box gives 480p via XBMC which is great and I actually use that as my PJ's DVD player.
    Infact i've just tested out the PS2 now (as i've got it connected to my PJ via component) and it kicks out 480i where as the X-Box does 480p. I tested the same dvd scene on both and the X-Box was considerably better as you'd expect.
  13. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Yep mine does - only ever used it once between dvd players and it was an awful experience! :(
