Playstation 2 on JVC LT-32DS6
Discussion in 'LCD & LED LCD TVs Forum' started by Shonte, Sep 15, 2005.
Tags:
  1. Shonte
    Shonte
    Aug 4, 2005
    138
    +4
    Hi there.
    A friend of mine has recently purchased a JVC LT-32DS6.
    He is running his playtation 2 through one of the RGB scarts on the tv using an RGB PS2 scart lead.
    It doesn't look as good as I think it should do, which leads me to believe there may be a better way of connecting it up, or there may be a better cable that can be purchased.
    Does anyone own the above set? If so can you advise us on how you have yours set up with regards games consoles?
    Thanks in advance :)
  2. Shonte
    Shonte
    Aug 4, 2005
    138
    +4
    Any ideas?
  3. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    Most of the time, these kind of "free" scarts tend to be pretty bad...so maybe try and get a better one from somebody you know. Else, try the component connection...
