Playstation 2 'fascia/housing'
Discussion in 'Nintendo Forums' started by StoneGhost, Dec 11, 2003.
  1. StoneGhost
    StoneGhost
    I was wondering if there is some sort of product I can put my Silver PS2 in.
    Basically I want to put my PS2 on my AV rack but it looks too untidy because of its small size, controllers and cables. I'm looking for some sort of box/tray which is the same size as most AV equipment, this could also hide the controllers and cables away while still looking stylish.
    I've considered a faulty DVD or video that I could 'hollow out' and put some padding in but I was wondering if anyone knew of a product already out there.
  2. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,690
    +884
    how about wireless controllers, will clear most of the mess up, i'm not sure putting it in a box would be a good idea from a ventilation standpoint.
  3. StoneGhost
    StoneGhost
    Thanks for replying!! heat would certainly be a consideration but i plan to remove it from any tray/fascia/box when playing.
    It's really just to make it look 'pretty' when being stored on my AV rack with my other stuff.
  4. sjallen
    sjallen
    Wait for the "PSX". Problem solved!
