playstation 2 and surround sound
Discussion in 'Nintendo Forums' started by mikeinsthelens, Dec 2, 2003.
  1. mikeinsthelens
    mikeinsthelens
    I have bought my Son a PS2 for Xmas (at least thats what he thinks!) and was wondering if I could connect it to me Home Theatre System?
    If this is possible could someone tell me what equipment I would need, and the best games for playing in surround.
    Regards Mike
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    I think the best a PS2 can output is Pro Logic in games.
    Just buy a toslink optical lead and plug it into your ps2 and receiver mate.
  3. puddleduck
    puddleduck
    Jan 24, 2003
    1,853
    48
    Lake District, near as dammit
    +59
    I'm pretty sure the PS2 can output DTS for games too, now that DTS have developed an SDK to allow DTS encoding during actual games.
  4. whuuf
    whuuf
    Sep 26, 2003
    183
    Essex
    Has your reciever got pro logic 2? If so just connect your ps2 with your reciever through the digital out and the pro logic 2 should make it surround for you.
  5. mikeinsthelens
    mikeinsthelens
    Right ok, so there is a port on the back of the PS2?, and this connects to my port on the back of the DVD player?
    Sorry if this seems obvious but I need to check
  6. wolfeh
    wolfeh
    Feb 21, 2003
    500
    Ramsgate, Kent
    +10
    Hi, GTA: Vice City came with 4.1 "Interactive" DTS. Wasnt exactly brilliant iirc.
    If you want to connect the PS2 to whatever you are using as a surrond receiver, you will have to buy an optical cable that you plug into the back of the ps2 (the port is next to the regular av socket on the back of the ps2) and then plug the other end of the cable into a optical IN port on your receiver.
    So the answer to your last question is yes :)
    wolfeh
  7. mikeinsthelens
    mikeinsthelens
    Thanks mate. Im sure there will be many more questions come xmas!! :smashin:
  8. nealgs
    nealgs
    Nope, the PS2 plugs into the connector on the back of your AV receiver/AMP not into the DVD player.
    Hope that clears that up properly
    regards
    Gary
  9. mikeinsthelens
    mikeinsthelens
    ERM no! :rolleyes:
    I dont have an AMP, the optical in connection is on the back of the DVD player.
    Sorry not sure what you mean by AV receiver:confused:
  10. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    SSX3 on the PS2 has DTS sound - it's pretty good, when you race against the other competitors you hear the odd insult hurled at you from over your left shoulder! :D
  11. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,770
    2
    In a secret location with Jennifer Lawrence
    +9,570
    I thought you said in your first post you wanted to connect it to your Home Theatre System.
    But you say you don't have an amp.
    What are you classing as a home theatre system?
    Greg
  12. nealgs
    nealgs
    Ahaaaa, Ok, the optical connection on the DVD IIRC is an out only. You use either an optical or co-ax cable to take the audio output from the DVD player to you AV (Audio/Visual) Amp or reciever.
    This is the unit that has 5 or more amps, to which you have connected you Home cinema speakers (Fronts/Centre/Rears/Sub etc)
    You PS2 has an optical output, this will need an optical cable (toslink - as mentioned above) which you then connect to one of the optical in sockets on your above AV Amp/Reciever
    does this explain any better??
    can you tell us what your home theatre system is (make/model) etc.
    regards
    Gary
  13. mikeinsthelens
    mikeinsthelens
  14. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    I think you're up a gum tree with one of those sadly as the amp is in the sub box and I would have thought your connection options were a bit limited.
  15. mikeinsthelens
    mikeinsthelens
    :suicide:
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Perfect time for an upgrade!!!
    Did you get the new Silver PS2???
    SSX tricky has DTS 4.0 for the game and is very good (better than ProLogic and stereo)
  17. mikeinsthelens
    mikeinsthelens
    Upgrade of what?? I have only just bought them! Hence :suicide:
    I didnt get the Silver one because every shop in this area had sold out!!
    Prol Logic sound will do for me not bothered about 5., but from what I can gather even that isnt possible with the set up I have got
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Thats why time to upgrade! when did you get the system, send it back if you can !
  19. nealgs
    nealgs
    As a few have mentioned, their is no additional Optical inputs on that Home Theatre System, according to the website link there is 1 optical link, which is more than likely taken up with you DVD players optical out.
    Only solution is UPGRADE time :) :clap: :smashin:
    Gary
  20. mikeinsthelens
    mikeinsthelens
    The optical Input on the DVD player is NOT being used for anything at the moment.
    I am getting sound from my SKY box and TV through the analogue.
    Dont know if this changes anything
  21. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If it has optical in and DVD player is decoder then PS2>DVD (decoder) then it should work, weird ass system though!
    "Audio input: analogue x 1, digital x 1 "
    SO there you go! Should work fine
  22. mikeinsthelens
    mikeinsthelens
    Cheap Ass System!!!:D
