Playlists ?
Discussion in 'Headphones, Earphones & Portable Music' started by jordan2pip, Aug 17, 2005.
  1. jordan2pip
    jordan2pip
    I would like to create a Playlist '80's Music' but I have some questions. When I import a CD, can I put the songs directly into the playlist or does it store the artist & album information 1st and then I have to copy the song into the playlist? I would like to minimize the # of artists & albums accordingly and am open to suggestions.
    Thanks!
  2. HMHB
    HMHB
    Nov 11, 2001
    26,857
    Nottinghamshire
    +5,637
    What software are you using to import your CDs ?
  3. jordan2pip
    jordan2pip
    I am using Sonic Stage.
  4. HMHB
    HMHB
    Nov 11, 2001
    26,857
    Nottinghamshire
    +5,637
    I which case I will step aside and let the SonicStage experts take over :)
  5. shadowritten
    shadowritten
    I think it's rip first, then create playlists (I haven't discovered any other methods, anyhow).
    Doesn't SS use M3U playlists? Couldn't these be imported from elsewhere? Never tried ... but still think it would be a case of importing/ripping tracks first.
  6. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    The best advice I can give would be, import as MP3s in any application you like. Then, in your choice of media player (not iTunes because it doesn't have great support for M3U) organise your music.
    If you are doing this in Winamp, drag your music into the playlist window in any order you like (you can always shuffle later, so the order isn't important unless you want a sequence). Then, once all the tracks are in the playlist, just save in winamp as an M3U list. You can put this anywhere.
    Then fire up SS, import - m3u playlist.
    You are done. I use SS like this all the time, because my music library is too big, and too badly tagged for any software to deal with it. M3U lists are good because they work on pretty much everything.
  7. JB5
    JB5
    Apr 18, 2005
    231
    +16
    Another alternative is to use the Genre entry in SS instead of playlists. Label the individual tracks or albums with genre = 80's. Pull up the genre list from the menu on your player and away you go!
  8. Sasso
    Sasso
    I was just thinking of suggesting that, but then i thought, doesn't 80s music have more than one genre?
  9. JB5
    JB5
    Apr 18, 2005
    231
    +16
    Sure, but you can have as many 80's genres as you want. 80's pop, 80's electronic etc.. Trouble being that you then end up with almost as many genre entries as artists etc..
    As a solution it's not without drawbacks and depending on how the original poster wants to use playlists may not even be appropriate, just something else to consider. :)
  10. shadowritten
    shadowritten
    Anyone using Gracenote (so, Sony and Apple, then) will know that the bewildering number of sub-genres available for selection for various types of music means that, unless you manually alter these, you WILL have as many genres as artists!
  11. shadowritten
    shadowritten
    I stick with 7 genres, and these work well for me: Classical, Dance, Folk, New Age, Pop, Rock, Soundtrack. Everything I own on CD will fit one of these 7 (and handily, there's a 7-line display on my HD5H, so I can see them all at once!).
