Playlists on Sony NW-HD3
Discussion in 'Headphones, Earphones & Portable Music' started by Diyolddog, Mar 30, 2005.
  1. Diyolddog
    Diyolddog
    :hiya:
    As you all know playlists are NOT possible on the HD3.
    However, if you put together a compilation of the tracks you want (using Magix MP3 for eg) and create an audio CD.
    Now using Sonic transfer this into an Atrac and onto your HD3.
    Then you have (in essence) an album that is in fact your playlist. :cool:
    :rotfl: :thumbsup: :D :smashin: :hiya: :clap: :rolleyes:
  2. shelteringsky
    shelteringsky
    yes but that doesn´t solve the problem at all. what if you want to make a playlist based on your player songs but without repeating songs???????? :thumbsdow
  3. Diyolddog
    Diyolddog
    And the point is ??? :cool:
  4. Akasan
    Akasan
    Mar 19, 2005
    68
    You can place songs in various groups this doesn't change the album information. Groups equal playlist. I also create custom genres so I can essentially have a song on two "playlists" without having duplicate songs.
  5. bstonehouse
    bstonehouse
    May 27, 2003
    501
    28
    +54
    The only way I have found around this is to create a 'compilation' in SS and then to change the 'Source' field in all the tracks to a unique name i.e songs for gym etc. and this then becomes the album name, this stops the songs being duplicated in the real album, although it does mean that the songs are tranferred to the player twice.
  6. human doughnut
    human doughnut
    on the player itelf you can create "bookmarks" for certain tracks. This is close to a play list, only it is a real shag trying to remove tracks, also adding the tracks isn't particually easy either.
  7. shelteringsky
    shelteringsky
    So you have to create a compilation based on songs you already have in your player, then you transfer that compilation to HD3 (before or after having change the "source field" them?) and that´s it? I don´t understand very well. I don´t know if it´s because I´m not english or because I´m a little bit thick... Can you be more explicit please? I´m really interesed on this thread!
    are you sure that this way you are not duplicating?
  8. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    Yes he is duplicating. The songs are on the player twice, using up additional space. But because on the two songs there are different album titles, ie. the original album title and the "playlist" title, they won't appear duplicated when you search through the album.
  9. shelteringsky
    shelteringsky
    oohh... that was waht i was referring to... what a pity. I have the player almost full and would have liked to have some playlists....
