Playing Xbox one on a 21:9 monitor?
Discussion in 'Xbox One' started by Razer, Jul 20, 2015.
  1. Razer
    Razer
    Jul 20, 2015
    2
    4
    Michigan, USA
    Hi I was thinking of buying a LG34UM95 monitor . Is a 4k monitor . I was wondering if Xbox one will run on it and I heard Xbox one only supports 16:9 and my monitor is 21:9. I
    Play FIFA and GTA Online if that helps.
  2. ObsidianEclipse
    ObsidianEclipse
    Nov 3, 2014
    169
    Mansfield
    +44
    It will either stretch the screen or run it at 16:9 with black bars down the side I'm afraid. So you will be able to use the monitor but you won't get any better resolution than a HD TV.
  3. Razer
    Razer
    Jul 20, 2015
    2
    4
    Michigan, USA
    What will the quality be if it stretch the screen and do you recommend better monitors
  4. IrritatedBadger
    IrritatedBadger
    Oct 12, 2008
    5,835
    +2,056
    You don't want to stretch it. It will look off.
