New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Just change your pictures aspect via the tv remote. I do this all the time from a Dell laptop to a 42 inch Plasma. The VGA has a resolution limitation so you cannot make it bigger via the laptop.
You can connect to a USB portable drive ( check power if not run with external P/S ), provided the drive is formatted in FAT32.
A link here gives some information. Sony: How to play MPG files on Sony Bravia - solution!
Manual will tell you files supported. Or you could use a 8gb Fat32 USB Memory stick
As another poster has said you could connect with a Server on PC wirelessly through router ( DLNA). Although I never could only with ethernet.
