Playing video files on Xbox 360
Discussion in 'Xbox Forums' started by Zola_Blue, Sep 7, 2007.
  1. Zola_Blue
    Zola_Blue
    Dec 31, 2000
    24
    London, England
    Does anyone know if it possible to transfer video files to the Xbox's hard disk and play them directly from the Xbox? (i.e. not streaming them from a PC)
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Unfortunately it's not. The only thing you can do is rip music CD's to the HD.
  3. TylerDurden
    TylerDurden
    Nov 6, 2005
    4,139
    +622
    Or you can convert / download wmv (or wmv hd) files and copy then to an externall HDD, connect that via usb and the 360 will play those (and music / photo files)
  4. Zola_Blue
    Zola_Blue
    Dec 31, 2000
    24
    London, England
    Cheers Tyler.
    Can you or anyone please recommend a good free avi to wmv converter?
  5. bubs999
    bubs999
    Apr 8, 2007
    3,186
    Hampshire
    +634
    I use Win AVI it can be found on the interweb
  6. Zola_Blue
    Zola_Blue
    Dec 31, 2000
    24
    London, England
    This was much easier than I thought it would be.
    1. Repartitioned my Western Digital External HD to Fat32.
    2. Converted some avi movies to wmv format using Winavi.
    And hey presto the Xbox 360 recognised the HD as a portable device and played the movies without any problems.
  7. dbwinter
    dbwinter
    Oct 13, 2006
    692
    63
    +368
    What about for a MAC running OSX?
  8. TylerDurden
    TylerDurden
    Nov 6, 2005
    4,139
    +622
    Good isn't it :smashin:
  9. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    Can WMV files be played over the network without Media Centre or do they need to be put on DVD/USB HD?
  10. para munki
    para munki
    Mar 27, 2007
    54
    Sheffield
    +3
    Only problem you may have is if you get files bigger than 4 gig as FAT32 cannot support them and for some reason a 360 wont recognise NTFS.
    Only way around this is to format you HD for HFS (MAC file system) which for some reason the 360 recognises and supports large file sizes
  11. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    Yes they can.
    You need to have either Windows Media Connect or Windows Media Player 11 installed.
    You can then access them through the media blade/video/PC
  12. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    Excellent only problem now is when I select to use computer to stream video from I've got no options now other than Tversity which I was testing out and don't want to use.
    Any idea how I can clear that out of there and go back to the default where it will search the network for a computer?
  13. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    I think you need to go to the settings blade/computers and then disconnect.
    Then go back to media blade/video and search for your PC again.
  14. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    I have tried TVersity but I don't think my PC is up to the transcoding (P4 3Ghz).
    I personally find Media Connect can stream WMV-HD fine, whereas TVersity seemed to struggle for some strange reason (even though no transcoding is going on).
  15. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    If you're after Windows Media Connect 2.0 (latest version), you can find it here!
    I don't believe MS have it available on their site anymore as they want everyone to use WMP11.
  16. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    Thanks will give it a try, Tversity was painful - my pc is pretty old and it took ages to open files and used all the cpu. Good job I wasn't planning to use it for general video playback.
    I only want the xbox to do VC-1 endoded WMV's that my network player can't do, I know they can be run from the disc drive but most of the files need a double layer disc.
  17. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    Clips don't run smoothly and for some reason windows firewall doesn't like it.
    Will have to try a spare USB drive formatted to FAT32.
