Playing Uk Radio stations on Netgear MP101
Discussion in 'Headphones, Earphones & Portable Music' started by Jedfordski, Sep 18, 2005.
  1. Jedfordski
    Jedfordski
    Aug 12, 2005
    109
    16
    Penarth
    Hi guys,
    I'm running Twonky as a front end for my iTunes collection played on a couple of Netgear MP101s. My music and playlists run fine, but I'm having trouble playing certain radio stations. On iTunes I can find and play Virgin Radio but I can't find it on th Netgear. I've tried making a playlist containing the radio station but that doesn't show up either. Any ideas?
  2. andrew1810
    andrew1810
    Apr 4, 2004
    1,035
    Northumberland
    +54
    Try the suggestions here:
    http://www.expansys.fr/forumthread.asp?code=111214&thread=118
    You need to make sure the playlist is an m3u file and then play it from the playlists section, not from the internet radio section.
    The MP101 won't play all of the radio stations listed in itunes by default. Twonkyvision is merely a front-end for the XML file created by itunes which points to the individual mp3's, it does not access the itunes radio at all.
