Playing SVCD
Discussion in 'Blu-ray & DVD Players & Recorders' started by waylander, May 16, 2002.
  1. waylander
    waylander
    Jan 31, 2002
    I have purchased a couple of SVCD's and have trouble playing them on my pc, is there a particular media player suitable for them.
  2. Squirrel God
    Squirrel God
    PowerDVD reckons it can play VCDs as well as DVDs....
    "PowerDVD allows you to play practically anything with digital content, and this includes VCD formats (Video CD and Super Video CD) or audio CD. Of course, because of VCD/SVCD's inherent limitations, it will not be able to fully utilize all DVD functions.
    Keep in mind that SVCD is relatively a new format, and like VCD, the authoring will be different title from title."
    http://www.gocyberlink.com/
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The Elecard media player handles the format with no problems.
    I assume the discs are "pirates" since SVCD is not an official format and even DVD players that support it do not say so in their manuals.
    http://www.elecard.com/
  4. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    SVCD is an official format and I believe you can buy legal versions of some films in the far east. It was developed by the Chinese to avoid the DVD licence royalties. The problem is that you need lots of CDs for a film.
    See http://www.uwasa.fi/~f76998/video/svcd/overview/
    I'm using the format for my home videos to play on my DVD. Lots of the cheap Chinese players boast of playing the format.
    To play on a PC you need DVD software as the MPEG2 codec is licenced. I don't think there any free players, but I could be wrong.
    Steve
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Correct. It basically used MPEG-2 compression instead of MPEG-1 (VCDs) for video, thus you can benefit from a higher resolution.
    Quite suitable for camcorder footage / backups.
