Playing Spotify / Itunes from Iphone 5S to Audi
Discussion in 'Motoring' started by Woodywizz, Feb 5, 2014.
Thread Status:
Not open for further replies.
  1. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    Hi - quick question, and please be gentle as I have no idea about these things.
    A couple of months ago I bought an Audi A4 SE Technik (13 plate) and am really pleased with it. After getting use to the Audi MMI, I am now seeing what more I can do. I want to play music - specifically from my Spotify Premium app on my Iphone 5S - via the Audi interface.
    How do I do this?
    A friend at Audi has said that I need a cable (AMI) to connect the phone to the car, but - because I have an IPhone 5S - I need an adapter for this cable from Apple.
    Any help appreciated....please!
    [​IMG]
  2. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
  3. grantsteve
    grantsteve
    Apr 17, 2005
    1,482
    Birmingham
    +230
    Does the Audi have a USB port?
  4. mikeburns
    mikeburns
    Jan 7, 2003
    799
    Stratford Upon Avon
    +321
    I've also got a B8 A4 but unfortunately I only ever connect my 5s via Bluetooth and only for calls. Saying that once paired whatever sound comes out of the phone it is relayed to the speakers but probably not too high a quality. I just use a USB stick for all my music but that's not much use if you want to use Spotify!
  5. mikeburns
    mikeburns
    Jan 7, 2003
    799
    Stratford Upon Avon
    +321
    Just thinking, can you plug the USB charging cable that comes with the phone, directly into the USB connector in the glove box?
  6. Epicurus
    Epicurus
    Jan 17, 2006
    3,706
    +696
    Nice car man, the SE Technik is a good trim.
    If Audi don't make the exact 5s AMI cable then you'll need the lightning plug converter as well.
  7. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    I have an A7 so this may differ slightly but I do play Spotify via AMI from a 4S, 5 and 5S
    I use Bluetooth and it works just fine. Remember that when Apple moved to the lightning connector, they made it very clear that connecting using cables for audio was so last year and that their focus moving forward would be audio over WiFi (AirPlay) and Bluetooth
    You first need to pair the phone (of course) then select SOURCE under MEDIA.
    I have had a number of A5s and A4s as loaners and they don't all come with AMI so you need to check if your car has the option but assuming it does then yes it works just fine
  8. Exemplar
    Exemplar
    Apr 4, 2005
    5,124
    3
    Newark On Trent
    +1,474
    My wife's A1 does this via bluetooth.
  9. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    Try audi-sport.net if you cannot get your question fully answered here. A quick search of the term 'Spotify' turns up quite a few threads.
  10. IronGiant
    IronGiant
    Jun 7, 2003
    66,493
    +46,701
    I think the AMI cable will come with the old style 30 pin Apple plug, so what you want is a lightning to 30 pin adapter like this:
    Digital Save® iPhone 5 5C 5S Adapter 8 pin to 30 pin: Amazon.co.uk: Electronics
    Note, this is for illustration purposes only, I don't know if it's suitable.
    It might be safer to get this: Lightning to 30-pin Adapter - Apple Store (UK) or Lightning to 30-pin Adapter (0.2m) - Apple Store (UK)
    An AMI micro USB cable would connect to the micro USB adapter you linked to but you may find it can't communicate over it, just charge the phone.
  11. gibbsy
    gibbsy
    May 17, 2007
    13,623
    3
    Cwm Cynon, De Cymru
    +7,611
    I've just ordered a Q3 and the brochure says ''Provides connection to Apple iPod from 4th generation and Apple iPhone. Bluetooth for handsfree mobile phone connectivity and Bluetooth audio streaming (depending on compatability of mobile phone).''
    Can't see it being too different across the range.
  12. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    42,913
    11
    13
    167
    ::1/128
    +16,332
    I would just use the Bluetooth streaming as explained earlier. Forget about spending money on the cables for ami etc. although it could be handy for charging whilst streaming.
  13. Pawsher
    Pawsher
    Sep 22, 2013
    11
    +10
    Bluetooth for me as well ...... works treat on my Audi A1, and Audi have yet to bring out an AMI cable for the 5/5s .....
  14. rousetafarian
    rousetafarian
    Aug 17, 2007
    23,663
    2
    NW
    +15,603
    +1 for Bluetooth, if it works in the Merc it will work in the Audi too
  15. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    Thanks everyone for your replies - will see if I can connect via Bluetooth.
  16. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    Right - I can connect the phone via bluetooth, and this is fine for calls. But for the life of me I cannot get it to stream music via bluetooth. If I click on 'Media' > 'Source', it brings up this : [​IMG]
    If I then click on the bottom option (which I presume I should) it then brings up this....and I can do nothing from thereon?? Thoughts please chaps.
    [​IMG]
  17. Dony
    Dony
    Aug 10, 2006
    18,540
    2
    near Newry, Co. Down
    +11,373
    What happens when you click on Jukebox?
    You can see at the bottom of the screen that bluetooth is connected, should you then change a setting in your phone to transfer music to the new device?
  18. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    maybe i should RTFML? :)
  19. Dony
    Dony
    Aug 10, 2006
    18,540
    2
    +11,373
    Did you get it working?
  20. Pawsher
    Pawsher
    Sep 22, 2013
    11
    +10
    'Jukebox' is a hard drive to store your music on. And WLAN is your wireless network you can create via Sim card.
    Go to 'Phone - highlight your phone and settings, and tick Stream music' ..... all this is from memory on my A1 so maybe slightly different to war I remember ..... but you can do it.
    Can check tomorrow for you
  21. Pawsher
    Pawsher
    Sep 22, 2013
    11
    +10
    Also ... press the voice command on your steering wheel , and say 'Bluetooth' it will then stream music from your iPhone
  22. mikeburns
    mikeburns
    Jan 7, 2003
    799
    Stratford Upon Avon
    +321
    Strangely you also need to switch on 'music streaming' under the Bluetooth menu.
  23. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    12,109
    Essex
    +3,035
    Don’t you also need to select the car as the output from the airplay menu on the iPhone?
  24. Pawsher
    Pawsher
    Sep 22, 2013
    11
    +10
    No, just does it automatically :)
  25. IronGiant
    IronGiant
    Jun 7, 2003
    66,493
    +46,701
  26. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    I'm just confused and still not able to do it! FML
  27. Pawsher
    Pawsher
    Sep 22, 2013
    11
    +10
    Have music playing on your iPhone, click 'Media' on headunit. Now is the option to play music from Jukebox, SD card etc yeah ? (As pic you posted) Press your voice command button on right hand side of your steering wheel (next to sat nav button) and say 'Bluetooth' after the beep.
    Now your iPhone should stream thro your car.
    PS ..... you have bonded the iPhone to your car yeah ?
  28. Pawsher
    Pawsher
    Sep 22, 2013
    11
    +10
    And ..... you can now buy a AMI cable for the 5S from your local Audi dealership :) About £30, AMI socket is in glovebox methinks
  29. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    Thanks Pawsher - I've done it. Went into Phone settings on the MMI and the Bluetooth Audio option was set to 'off' - so I set it to on :
    [​IMG]
  30. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,397
    Manchester
    +6,135
    Then went into "Media" and "Source" - and it showed the phone, so connected it as a media source - and now it plays Spotify from the phone via bluetooth to the car - no cables needed.
    Brilliant, and thank you
    [​IMG]
Thread Status:
