Playing online with 2nd PC
Discussion in 'General Video Gaming Chat' started by Contar, Apr 29, 2004.
  1. Contar
    Contar
    Mar 2, 2003
    105
    Near London on the M1
    Can some help me with my gaming access on a 2nd PC.
    I have my fisrt PC running windows XP pro connected to NTL cable using the usb connection on the modem. I then run to a second PC upstairs through a hub on a diffrent ip with the PC downstairs acting as a router.
    I have internet access on both but the upstairs PC cannot play on line games. Any settings I should do etc or any websites I should look at ?
    Cheers :lease:
  2. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    have you tried
    www.gamespy.com
    this is used by most people for pc internet gaming
    there is a pice of software to download to make this possiable
    but has been a while since I used this cant quite remember where on this web site it is
    :oops: found it try this link instead
    http://www.gamespyarcade.com/
  3. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    What games are you trying to play and are you using any matchmaking programs?
    Sounds to me you have some NAT issues with the router software. What router software are you using? Or are you just using ICS?
  4. Contar
    Contar
    Mar 2, 2003
    105
    Thanks for the replies guys. I am mainly trying to play Starcraft and various Halflife mods. My "router" is my PC with internet sharing applied from the standard stuff on Windows XP Pro. 2nd PC is also windows XP but Home edition.
    Should I get something better ?
  5. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    The problem is with ICS, it does have problems with games, you should be able to play games with 1 PC at a time, it cannot cope with both.
    Your best bet would be to buy a hardware router, either wireless or cabled and use it that way.
  6. Contar
    Contar
    Mar 2, 2003
    105
    Thanks Sinzer. I have looked at a router before but did'nt get one as ics is free, but it don't do what I require so a re-think is in order.
