Playing Multichannel DSD / DSF over DLNA
Discussion in 'AV Receivers & Amplifiers' started by Roen, Jun 29, 2017.
  1. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    I currently have a Serviio server setup on my PC, which feeds DSD (and PCM) files to my Yamaha RX-A660. 2ch DSF's are a breeze to listen to.
    I recently encountered an iso file that has both stereo and Multichannel tracks. I used SACD_extract to extract the stereo DSF's in one directory and the Multichannel DSF's in another.
    The stereo files play over DLNA. In the signal info screen, the info shows up properly as 2.0, DSD64.
    However, the Multichannel files refuse to play at all. The receiver sees the file on the server, but I suspect, cannot decode them.
    How do people on this forum listen to digital Multichannel DSD files through their receiver?
  2. Violator
    Violator
    Jun 19, 2007
    1,689
    116
    Chester
    +556
    Serviio can't do multichannel DSF over DLNA. Do you have the option to convert to PCM? That should work.
    Alternatively convert them to 5.1 flac with something like foobar2000.
  3. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    You just killed my dream.
    But thanks for that. Do you know of any other DLNA servers that supports multichannel DSD?
  4. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    Also, nvm. My receiver doesn't support multichannel decoding via the onboard DAC for any type of digital file.
  5. dante01
    dante01
    Mar 5, 2009
    44,908
    +10,551
    AV receiver cannot play multichannel DSD if sourced using their networking capabilities or if sourced via their USB inputs. The only input multichannel DSD can can be accessed via is via a receiver's HDMI inputs. DSD and DSF via a receiver's networking abilities and USB inputs is restricted to 2 channel stereo. The same goes for multichannel FLAC and or any other multichannel audio format. It is stereo only and a maximum of 2 channels if wanting to access audio via any AV receiver networking capabilities.
    The solution is to access the files using an external media player and use that player to play the files. The external media player would then need to be connected to the AV receiver via HDMI in order to convey the resulting multichannel DSD or PCM to the receiver.
  6. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    Denon's and Onkyo's seem to do it?
  7. dante01
    dante01
    Mar 5, 2009
    44,908
    +10,551
    No they don't.
  8. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    What makes the digital data in USB different than the digital data in HDMI? Do they not get processed through the same DAC?
  9. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    Also, spec sheet on the Denon's AVR-X7200W claim multi channel support in the file formats, but does not specify transport.
  10. dante01
    dante01
    Mar 5, 2009
    44,908
    +10,551
    No AV receiver facilitates playing multichannel audio accessed via either their networking abilities or via their USB inputs. THese two interfaces are restricted to stereo audio. This includes the Denon AVRX7200.
  11. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    Do you know the reason why?
  12. dante01
    dante01
    Mar 5, 2009
    44,908
    +10,551
    Not really. I can only guess that it has to do with the signal paths. The USB inputs usually relies upon the same board used for a receiver's networking hence why both are subject to the same restrictions. This also suggests that the audio accessed in conjunction with that board is subject to a different decoder than that associated with the receivers other digital inputs? The DAC will be the same DAC, but the signal path to that DAC will differ for the networking board when compared to the HDMI board for example. I'm quessing the signal paths are only stereo in nature so audio is therefore restricted to 2 channels?
    Anyway, for whatever reason, AV receiver do not handle and cannot play multichannel audio accessed via their networking abilities.
  13. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    Also, I did make a mistake.
    The spec sheet for the Denon has the multichannel DSD only in the HDMI portion of the manual. In the USB / NAS section, the Denon can do DSD128, but makes no mention of multichannel.
  14. Violator
    Violator
    Jun 19, 2007
    1,689
    116
    Chester
    +556
    In answer to your original question OP, I play m/c flac/pcm files via my NAS>Mede8er>Anthem. Works well and you'd never notice the difference.
  15. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    What's the transport? USB? DLNA? HDMI?
  16. dante01
    dante01
    Mar 5, 2009
    44,908
    +10,551
    The files are being conveyed to the Mede8er media player over a network from the NAS. The media player is playing the files and the signal is then being conveyed to the AV receiver via HDMI.
    By the way, a transport is the device being used to play the content as opposed to the interconnections and protocols employed between devices to convey signals.
  17. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    I see.
    I was hoping for a straight NAS to receiver solution without having to go through an intermediate player and HDMI.
  18. dante01
    dante01
    Mar 5, 2009
    44,908
    +10,551
    What about devices you currently have connected to the receiver via HDMI. Do any of these have inbuilt DLNA networking and the ability to play the files in question? Some Blu-ray players include such abilities.
  19. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +8
    I have none.
    Just a STB and onboard Smart TV Apps.
    My receiver is essentially my Renderer.
