fluff34567
Established Member
hi,
not sure if this is the correct forum but its maybe the best fitting one??
anyway..... I was wondering if it is possible to get any sort of picture quality increase if you play a HD xvid file onto a plasma scren via a normal ( non upscaling) dvd player in my case a yam s-557?
Or am i correct in suspecting you either need an upscaling player or to play it thru a media centre pc to get the benefit?
thanks!
thanks!
