Playing HD Video .MKV files
Discussion in 'Microsoft Windows' started by stripe, Apr 17, 2007.
  1. stripe
    stripe
    Apr 7, 2004
    1,293
    Scotland
    +123
    I'm currently running a 3.2GHz HT P4 with 2Gb ram, an 8Mb 250Gb HDD and a 128 6600Gt VGA card. I'm trying to play .mkv HD video but after about 10 minutes into the video it starts periodically stuttering, then it plays again for about 5 minutes etc... The sound keeps playing throughout.
    Any ideas?
    Thanks in advance.
  2. stripe
    stripe
    Apr 7, 2004
    1,293
    Scotland
    +123
    Oh and it's just the 720p video files.
  3. Wicker
    Wicker
    Nov 29, 2004
    137
    United Kingdom
    +16
    Have you monitored your CPU usage during this time?
  4. ukkev2000
    ukkev2000
    Apr 12, 2004
    1,027
    48
    Hampshire
    +51
    Better than me, after 5 minutes the lipsync is so bad it's unwatchable. I know MKV's are just a container for the data inside but they are all snafu for me :( Maybe it's having K-Lite and CCP codec packs installed, maybe they don't get on.
    As for the OP, I'm finding WMP network service often decides to chew up all available resources for a random time before settling down again. HTH.
  5. pmc
    pmc
    Oct 18, 2004
    1,414
    +104
    Buy and use the CoreAVC codec
    http://www.corecodec.com/products/coreavc.html
    You'll need the Pro edition for deinterlacing 1080i material.
    Use this with Media Player Classic. It works a charm. I play those same MKV files you are talking about with a 3GHz PIV, 1 GB memory and a Nvidia 6200, no problems at all :thumbsup:
  6. stripe
    stripe
    Apr 7, 2004
    1,293
    Scotland
    +123
    Wicker I'll check the CPU usage tonight and see how it behaves.
    PMC how much is the codec, the website is down for a few days?
  7. lagertop
    lagertop
    Nov 30, 2002
    25
    3
    Vienna
    +4
    Michael, what codecs are you currently using for watching the mkv files?
  8. stripe
    stripe
    Apr 7, 2004
    1,293
    Scotland
    +123
    I removed and re-installed the latest version of FDDShow, and I'm playing it through media player classic.
    I ran a couple of films for about 30 minutes each and the PC never skipped once, so it appears to be working properly, the CPU utilisation is running at about 30% during playback.
