Playing HD clip on PC (AVI file)
Discussion in 'TVs' started by BenPremium, Sep 7, 2005.
  1. BenPremium
    BenPremium
    Nov 23, 2003
    329
    16
    I'm trying to play an AVI file that is supposed to be HD but it doesn't work.
    Windows Media Player says that it cannot play the file and it doesn't work in any other player either, including DivX.
    I'm not sure if I need some special codec and if I do, how do I find out which one?
  2. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    where did you get it?
    quicktime, divx and mediaplayer all have HD codecs which SHOULD automatically download when trying to play one..?
  3. BenPremium
    BenPremium
    Nov 23, 2003
    329
    16
    It's a bit torrent.
    Basically it says it isn't a valid avi file. I've downloaded every codec under the sun and even tried the legendary vlc player with no luck.
    I'm guessing it's not a valid avi file after all or possibly corrupt.
  4. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    Download a program called avicodec. It will tell you what the audio and video codecs are in an .avi file.
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,515
    London
    +1,005
    Try Media Player Classic, it plays most files. You can download MPC here. Choose MPC 6.4.8.4.
  6. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    could be a KVCD..? did you get a NFO file wih it?
    oh btw, be careful when discussing torrents here ;-)
  7. MDPlatts
    MDPlatts
    Aug 20, 2005
    276
    2nd City - Manchester, UK
    +21
    try it in windvd - I had a similar problem - but windvd (v4) played it fine.
