Playing HD camcorder videos on TV via DVD?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by medicmanonet, May 5, 2007.
  1. medicmanonet
    medicmanonet
    Apr 12, 2007
    254
    Cwmbran
    +18
    Hello All,
    bit of a daft question this, but here goes.
    If I buy a high definition camcorder (various makes) and then capture and edit on my pc can I write it to a DVD in a HD format file (H.264 AVC???) which can be played by a HD DVD player?
    I assume at this point that there are no HD dvd recorders for PC's. I am sure that there are Blu-Ray recordable drives for PC. Can you actually author your own High definition disks (HD-DVD or Blu-Ray)?
    Curently I have sony DV camccorder, which I can capture and edit on my pc and create a DVD quite happily. If I was to upgrade to a HD camcorder could I acutally play a edited HD home movie on my TV?
    Could I write a HD format file on to a DVD data disk (ISO / UDF), and would it be read by a HD dvd player such a a Toshiba HD-E1?
    As you can guess I am very new to this HD lark:suicide:
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes you can.
    There are 2 main High Def consumer camcorder formats - HDV and AVCHD.
    With HDV, you can create High Def DVDs on ordinary DVD discs which will play on a HD-DVD player, with menus and everything. Ulead Movie Factory software can do this.
    With AVCHD, these don't play on HD-DVD players, but they do play on the Playstation 3 and Sony Blu-Ray players.
  3. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    For now they are called Mini HD DVD,:)
  4. medicmanonet
    medicmanonet
    Apr 12, 2007
    254
    Cwmbran
    +18
    hey guys thats awsome.
    So as long as I get a High Definition Camcorder with HDV or mini HD DVD and use the right software on my PC I can write the HD film to a normal DVD (single or dual layer) and still play the HD movie on my Tosiba HD DVD player.
    Hmm... I can see me sending Santa a new letter..:D
    Dear Santa, Please can I have a nice new HD Sony camcorder. I've been a good boy all year honest:devil:
    Thanks for the info folks
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes, but to be clear: Mini HD DVD is referring to the resulting DVD you have made. To do this workflow using a HD-DVD player you need a HDV camcorder, not a AVCHD camcorder.
    Or... the other option is AVCHD files can play on a PS3 or Sony Blu-Ray player.
    2 different formats, 2 different options. HDV goes with HD-DVD, AVCHD with Blu-ray/PS3.
    Edit: Further clarification - the above refers to putting HD on ordinary DVDs. For creating DVDs on a HD-DVD disc or Blu-ray disc the answers are different. E.g. you can put HDV on a Blu-ray disc and play that in a Blu-Ray player... but you can not put HDV on an ordinary DVD and play it in a Blu-Ray player... though you can play it in a HD-DVD player.
  6. Analogue
    Analogue
    Have read this thread with great interest and thanks to Redsox for clarification. My question is what length of HD video can you sensibly put on a standard DVD?
  7. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    With HDV video - 23 mins on a single layer, 46 on a double.
  8. Analogue
    Analogue
